Quicksilver 8417 Design - Stay with it or modify?
Old 12th June 2013, 11:11 PM   #31
45 is offline 45  Italy
45's Avatar
Originally Posted by llwhtt View Post
The schematic that 45 posted is an old Michaelson and Austin TVA-???, NOT a Quicksilver.
Craig
Yes, it's a mistake in fact there is SS rectifier. The QS had the 12FQ7's and a huge input cap as well in the power supply but with tubes! Rubbish anyway... The Michealson is even worse sound-wise.
Old 12th June 2013, 11:20 PM   #32
45's Avatar
Originally Posted by john65b View Post
Palustris, that is not an 8417, but the KT88 schematic....is the transformer impedance 4200 ohm? What is the tube compliment? Sorry, not familiar with that amp...
The QuickSilver were made with KT88's as well. 4.2K will work good.
Old 12th June 2013, 11:24 PM   #33
llwhtt is offline llwhtt  United States
After the "good" 8417s dried up the KT88s were used.
Craig
Old 14th June 2013, 12:51 PM   #34
john65b is offline john65b  United States
john65b's Avatar
Sounds like there are quite a few not impressed wiith the 8417 design.
I am considering the Peter Millet "Universal Input" PCB (need to confim it fits in my chassis). It has a pair of 6SN7 on input (I have quite a few) and looks to be an all in one option (kinda like my Aikido). I could choose the SS or Tube rectifier on PCB...is this a "Much Preferred" Design of the 12AX7/12BH7 Quicksilver design??
See schematic.
Question - (I may just send Pete an email thru ebay where he is selling these PCBs)
Using the 4.2k 60W Edcor Output tranny and a 450V B+, I should still get around 60 watts with this front end, correct?
I could omit input transformers and go Balanced in, correct?
If I go Single Ended in, and Ground the neg input, will it change the amp output if all else the same?
Sorry for the lame questions...
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 14th June 2013, 06:24 PM   #35
john65b's Avatar
OK, just realized the transformers do the phase splitting..why would you need one if you had balanced inputs? Am I missing something here?
I also just realized have a 1:1 transformer but it is 600ohm:600ohm (if I remember correctly - a Sescom MI-14?)
Likely not high enough on the input?
Old 23rd September 2013, 09:15 PM   #36
john65b's Avatar
OK, Next question for the 8417
I finally started the build and have the chassis complete...pics later...it will look pretty sweet...
I have a pair of NOS Sylvania 8417....is it worth buying two more Sylvanias ($140) for the other monoblock, or sell the 8417 and buy a quad of KT120?
Old 4th October 2013, 05:50 PM   #37
john65b's Avatar
Bah! I will stick with the original 8417 design -I even bought a quad of 8417 Sylvania tubes...simple changes: dual bias adjustments, and maybe a 6922 instead of the 12BH7, and some of those nice Russian .22uf/600V mylar coupling caps...Some pics (finally!) Just need to solder everything together...looking good so far...
Old 5th October 2013, 03:17 PM   #38
roline is offline roline  United States
roline's Avatar
Kt120's are harder to drive, you would have to have a really good driver..... Perhaps a MosFet follower to ensure adequate drive......
SO many tubes, SO little time!!!
Old 9th October 2013, 12:09 PM   #39
john65b's Avatar
Hello all, I have a quick question - these 8417 are to be biased at 100ma (50ma each tube). I am planning separate bias pots and meter points per 8417 output tube. Does the 50k bias pot have this current running through it? Reason I am asking I am trying to size the pot (1/4 watt? 1/2 watt 2 watt?). If I do the math, I should have around (60V - 15V) = 45V across the 50k pot so 45*45/ 50,000=.04 watts...but if the entire 50ma current goes through the 50k pot, we are talking a lot of wattage
The ones I normally see for fixed bias are usually only 1/4 watt.
Old 9th October 2013, 02:37 PM   #40
kevinkr's Avatar
I use 2W locking pots for bias, usually ETI purchased from mouser. Search on RV4LYSA503A at mouser.com and you will get the 50K locking pot. Only the bias currrent of nearly a mA flows through this pot.
Conservatively rated and reliable, I have never had a RV4LYSA series pot fail on me. (Made also by Ohmite and CTS)
I would recommend a lower value pot frankly of 5K or 10K with more current flowing through it. This will make the bias less prone to changing due to grid current, for the same reason adhere to the recommendations about max grid circuit resistance for the 8417.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Quicksilver 8417 Design - Stay with it or modify?Hide this!Advertise here!
Quicksilver 8417 question john65b Tubes / Valves 1 24th October 2008 07:40 PM
quicksilver 8417 biasing ozdiyer Tubes / Valves 2 26th August 2007 07:54 PM
Quicksilver 8417 Monoblocks dshortt9 Swap Meet 0 5th December 2003 03:57 PM
Quicksilver 8417 dreaded 42 Tubes / Valves 4 4th September 2003 11:14 PM
Quicksilver 8417 model changes Burnedfingers Tubes / Valves 3 12th April 2003 02:45 PM
Copyright ©1999-2017 diyAudio
