Quicksilver 8417 Design - Stay with it or modify?
Old 10th June 2013, 10:32 PM   #11
dirkwright is offline dirkwright  United States
dirkwright's Avatar
I think you'd be better off building a Williamson clone. But, that's just my opinion.
Old 11th June 2013, 02:02 AM   #12
john65b is offline john65b  United States
john65b's Avatar
Goat: Use the 12AX7 and the 12AU7 as phase splitter? According to the original schematic, nothing needs to be changed, correct (shows 12BH7 OR 12AU7)?
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 11th June 2013, 02:13 AM   #13
GoatGuy is offline GoatGuy  United States
Sin Bin
Yep that works too.
The reason that 300K resistor is hanging off the first-stage 12AX7 is to maximize gain to the near-limit. Choosing a pair of finals with lower mu ... increases the need for gain yet more. You could however, drive them at higher current draw ... with a little math work, and a slightly different transformer. So... use the KT88's. They're really quite nice.
GoatGuy
Old 11th June 2013, 03:07 AM   #14
john65b's Avatar
OK, so it looks like: keep the 12AX7, 12AU7 instead of the 12BH7, and the KT88. OK...
Old 12th June 2013, 08:46 AM   #15
artosalo is offline artosalo  Finland
artosalo's Avatar
Originally Posted by GoatGuy View Post
...The reason that 300K resistor is hanging off the first-stage 12AX7 is to maximize gain to the near-limit....
GoatGuy
Actually, no it isn't.
The reason for such high resistance is to bias the direct connected phase splitter to near optimum operating point. This kind of circuit is a compromise.
Both stages should be biased individually, as I have said earlier.
If the gain of 12AX7 stage wanted to be increased or maximized, it can simply be done by bypassing the 820 ohms cathode resistor with some 100 uF electrolyte.
This increases the gain some 2 dB.
Old 12th June 2013, 02:31 PM   #16
dirkwright's Avatar
Actually, it's both. The resistance is chosen to achieve the correct bias point for the following stage, but the supply voltage is made high enough to make that resistance very high to provide a high gain for the first stage. Bypassing the cathode resistor is just a small trick to get a little more gain in exchange for a lot more distortion. Like I said before, the Williamson circuit is superior to this thing anyway.
Old 12th June 2013, 02:51 PM   #17
DF96 is offline DF96  England
Yes.
Not necessarily. You would get a little more distortion in the input stage, but enough extra gain to reduce the much greater distortion from the output stage. There could be an effect on common-mode distortion in the first stage; bypassing might make this worse. The exact balance of advantage depends on details. Mullard and Leak always bypassed the first stage cathode resistor.
Old 12th June 2013, 03:21 PM   #18
artosalo's Avatar
The key point seems to be forgotten.
Direct connected voltage amplifier and cathodyne phase splitter is a compromise.
It is working well only when a pentode amplifier is used, since this operates at optimum point with sufficiently low anode voltage.
Therefore both should be biased and optimised separately.
Old 12th June 2013, 03:26 PM   #19
In this circuit adding a coupling cap would add an LF pole and possibly compromise LF stability. However, a DC potential divider with the upper resistor bypassed by a cap should be OK. That would give some separation of stages, at the expense of adding loading to the first stage. Once again, it all depends on details.
Old 12th June 2013, 03:31 PM   #20
45 is offline 45  Italy
45's Avatar
That's mine too. Quicksilver amps are among the worst commercial amps I have listened to. In my opinion they gained some popularity just because they came out in a time where tube amps only represented a niche and there were not too many around.
I have a friend who had the version with KT88's and he had to change the rectifiers every year! Really bad design. From the schematics it is easy to see why his rectifiers had short life. They were expensive and didn't sound good at all to me. The other models are not so much better....
Quicksilver 8417 Design - Stay with it or modify?Hide this!Advertise here!
Quicksilver 8417 question john65b Tubes / Valves 1 24th October 2008 08:40 PM
quicksilver 8417 biasing ozdiyer Tubes / Valves 2 26th August 2007 08:54 PM
Quicksilver 8417 Monoblocks dshortt9 Swap Meet 0 5th December 2003 04:57 PM
Quicksilver 8417 dreaded 42 Tubes / Valves 4 5th September 2003 12:14 AM
Quicksilver 8417 model changes Burnedfingers Tubes / Valves 3 12th April 2003 03:45 PM
