Old 6th June 2013, 06:38 PM   #1
b3nny11 is offline b3nny11  Yugoslavia
Lightbulb NOS GU-81
I just wondered how much does one NOS GU-81 vacuum tube cost.
i found a Man who has new tubes and he's selling them for 2000 RSD that's around 17.5385 EUR
so i think that's a preatty good deal. isn't it?
Old 7th June 2013, 12:44 AM   #2
roline is offline roline  United States
roline's Avatar
Are you going to make an amp that runs on 1 to 2KV B+ ??
SO many tubes, SO little time!!!
Old 7th June 2013, 02:27 PM   #3
i tought more of a tesla coil. i just wondered how much does one cost.
Old 7th June 2013, 02:35 PM   #4
''GSTube.com''. Tubes, sockets etc. Search result for <u>gu-81</u>
gstube wants 64 USD for one tube. 17.5 Euros seems like a good price for a big tube, to me.
-e
Old 19th June 2013, 10:17 AM   #5
AJT is offline AJT  Philippines
AJT's Avatar
i bought a bunch of tubes from this guy....
they were all good...
Old 19th June 2013, 03:06 PM   #6
Talking have fun reading this... -_-
lool pardon me not beeing online... well the tube arrived 11.06.13 and it even bigger as i immagined. i was blown away when i unpacked it! it's massive! i found a audio amp schematic from a german guy... elo.maanders GU81 Tube Amp / Röhrenverstärker Trafo+Anodenglühen - YouTube
and wired the tube up with the stuff i got... but not quite the voltages you see there... the max voltage i got from the transformer was ~670V the output transformer was some from a 3 w amplifier but it had some power itself... i used this Visual Analyser to generate frequency... the max voltage i messured with the multimeter was 2.7v @ 100Hz everything more or less was under 2.7v i used a 130W speaker and it just worked a treat... the sound quality was aswesome the bass was good but the higher frequencies just too loud until the bass kicked in..! no buzzzing or somesort of!... i was pretty amazed. i had it on for like an hour and the room just got too hot i had to turn the fans on it's pretty crazu how much heat can generate one tube... and yes i got shocked 3 times... i accidentaly touched the Top grid3 connector. it allso burned some hair on my arm the second time!
i'm getting more of these tubes pretty soon!
Old 24th June 2013, 05:47 PM   #7
hpeter is offline hpeter  Europe
hpeter's Avatar
GU-81M Pentode - Röhren: Odd Ball
TASCAM US200 -> JJ ECC803/6L6 headamp -> Beyers DT990pro 250Ω # ..intrigued by screen drive & G1 FB sound
https://plus.google.com/photos/10110...12393782517569 ____ http://youtu.be/iL9809xtif4
Old 24th June 2013, 05:51 PM   #8
hpeter's Avatar
same to me happened when saw in person my glass toys
i was like -what the f** am gonna do now with this beast ?!?!
Old 24th June 2013, 06:04 PM   #9
slovensko, hmm... tato stranka je z tyzdna na tyzden zaujimavejsia!
Old 24th June 2013, 06:06 PM   #10
hpeter's Avatar
NOS EL503 trade for GU-50 or similar Tekko Swap Meet 0 3rd May 2010 06:30 PM
EZ80 or 81 gr_virgmann Tubes / Valves 14 30th October 2009 10:56 AM
Aureavox Arcana 81 lduarte1973 Tubes / Valves 0 7th May 2009 06:34 PM
81 Rectifier Diy martin Tubes / Valves 4 14th January 2006 01:54 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
