Comments on 6C33C-B ARG OTL - diyAudio
Old 4th June 2013, 07:32 PM   #1
Default Can some one help explain 6C33C OTL circuit
Hi I am in the process of building a SET with 6C33C-B tubes, I found this tubes are also used in OTL amps, and the idea of building an AMP without having to invest in Output transformers seems excellent.
I have been reading about OTLs and came across this design form Eugene Kremiński from Lviv, Ukraine which is highly regarded by Lampizator. Is this design worth a try?
I really don't understand how the thing works, can anybody here comment and on the circuit design, pros and cons, has anybody built something similar?
Any explanation is welcomed.
Old 4th June 2013, 08:34 PM   #2
cnpope is offline cnpope  United States
It's a circlotron. A nice, very symmetrical, output stage. You can find various discussions and explanations on the internet if you google for circlotron. One nice discussion is in John Broskie's article
http://www.tubecad.com/articles_2003...irclotrons.pdf
where he explains a bit about it, and contrasts it with the other common OTL output topology, the totem pole. John Broskie has various other articles discussing OTL amplifiers on his website. I've built a couple of OTLs using 6C33C tubes; both of them are totem pole rather than circlotron, but they give a really nice sound. I've also built a circlotron using EL509 sweep tubes. Personally, having got into OTL, I'd never go back to building amplifiers with output transformers.
Chris
Old 5th June 2013, 03:47 AM   #3
Thanks Cnpope, Broskie's article is very enlightening even though I don't get one half of the stuff. I know transcendent sound, I even have Rozenblitz's two books, so I know about his patent. Very polemic issue this of Rozenblitz's patent being just the same OTL circuit of old. Needless to say I only get the airplane car analogy, but I don't get a bit of the explanation "dumb me".
Old 9th June 2013, 05:39 PM   #4
Can the power supply units in this Cicltron design be replaced by solid state regulated ones? What is the use of the hybrid power supply? is it just to delay start? What is the function of inductance LD1, LD2 and LD3? Are the really necessary?
Old Yesterday, 08:08 PM   #5
Check out the otl design by Tim Melow
I built one and it sounds better than any amp I have ever owned
Check out my post
New otl project
Any Progress is Progress
Old Yesterday, 11:02 PM   #6
Miles Prower's Avatar
Yes. It would be an improvement.
These are ripple filter chokes. It requires a separate PS for the front end. The finals can pull the required bigamps at very low voltages, but the front end requires higher voltage so's it can operate with good linearity. Passive filtering is easy and reliable. However, chokes that can handle the current demand of the finals are going to be quite heavy, as they'll need a lot of iron.
These could be replaced with either active decouplers, or active regulators. The whole back end could be replaced with power MOSFETs that can handle the current demand, and do it without requiring the heater power. Any VT that can handle bigamps will have power hungry heaters.
There are no foxes in atheistholes
www.dolphin-hsl.com
OTL design recommendation? (6C33C maybe?) arteitle Tubes / Valves 14 16th January 2012 04:37 PM
Preamp for Tim Mellow's 6C33C OTL flanagan Tubes / Valves 3 9th November 2010 08:13 PM
6C33C OTL DC schematic needed neazoi Tubes / Valves 29 25th June 2010 05:25 PM
Transformer for 6C33C OTL WALTER BURKHARD Swap Meet 1 29th June 2003 11:06 AM
Availability of 6C33C tubes? I need some for OTL amps tubetvr Tubes / Valves 39 31st January 2003 09:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
