type 27 pre
type 27 pre
Old 16th December 2003, 08:35 AM   #11
exurbia is offline exurbia  Australia
exurbia's Avatar
I knocked together the 27 pre last weekend. The sound is amazing i'll never go back to my accuphase pre, althouth the accuphase does have better facilities
I am using my power supply chokes in the anode feed, these are 450H. I want to go back to a valve rectifier using 5u4g, as i have a few. The problem is i no longer have the chokes, can i use a capacitor filter and if so is there a simple way to work out the required C and R.
thanks in advance, peter.
Old 22nd December 2003, 02:21 PM   #12
Burnedfingers is offline Burnedfingers  United States
Peter
I suggest you put the chokes back in the power supply and purchase several plate resistors and see if you can detect a difference. I have done this and I like the #27 with plate resistors as opposed to plate chokes. Just my .02
J
Old 22nd December 2003, 03:38 PM   #13
exurbia's Avatar
Gday J,
Thanks for your advice, i had already given up on the chokes they are back in my supply. I'm currently using 130R on the anode, I hate to say this, the tube type decides which resistance should be used. I have some deforest 427 with the punched shiny anode and a nipple on top. these run with 130, the 427's with the mesh anode run 150. I have lots of other 27's to try and it is quite a task.
Old 23rd December 2003, 10:49 AM   #14
Peter
I'm using 50K plate resistors and have 180volts on the plate and 12volts across the cathode resistor and it sounds every bit as good as the #26 did.
J
Old 26th December 2003, 04:01 PM   #15
stigla is offline stigla  Norway
Hi!
I am currently building a #27 pre for my brother. It will be loaded by Gary Pimms BBMCCCS, using the mu output.
Check out http://www.angelfire.com/ut/Likkhalt/index3.htm
to see schematic plus construction pic's so far.
I really look foreward to listen to this pre, I think it will be a stunner!! The tubes will be AC heated, so I hope I dont runn into problems with hum. I'll keep you posted about the sound when I get it running.
stigla
type 27 preHide this!Advertise here!
Another X-type Amp vdi_nenna Solid State 8 17th September 2008 08:58 PM
What type of CAP? Gophat Car Audio 4 28th April 2008 03:14 PM
different type of TVC? jesserparker Chip Amps 1 25th March 2008 03:25 PM
Re : BL type & GR type of transistor for Aleph-Ono Arion Pass Labs 4 29th January 2007 06:15 PM
