What do you think..OP Tx - Page 2 - diyAudio
Old 2nd June 2013, 02:42 PM   #11
el156 is offline el156  Portugal
el156's Avatar
Originally Posted by Cookj View Post
Anything from the USA has become uneconomic due to postage and import duties.
It is better to source from EU countries ie Valves Stuff or RITTER electronic systems--Die Röhrenspezialisten seit 30 Jahren! - these are good BUT be aware that they will only accept payment via IBAN. A general problem in Germany.
A good site that accepts PayPal is Tube-Town - Hot Stuff cool sounds - excellent service
Cheers
John
Hi Cookj ! I was having a look to this RITTER electronic systems, and they sell output transformers at very good prices, but i dont know the quality of this transfos ! Did you ever tested one of those ? Can you tell me something about the quality ? Thanks
Old 5th June 2013, 02:41 PM   #12
M Gregg is offline M Gregg  England
Just for interest..
M. Gregg
Old 7th June 2013, 05:02 PM   #13
Progress..
Is a little slow ..
M. Gregg
Old 12th June 2013, 12:58 PM   #14
Well,
after looking at a few other makes of OP Tx...edcor has better low frequency..I'll use Hammond mains..(Keep the weight down)
Then whats in the box ?(rectifier) 5y3...It can be used horizontal if the pins 2/4 are vertical...I'll try and get it upright...
NB its an all valves/Tx's mounted in the box build I hope..
A couple of Mullard EF86 (Paint missing from a quick wash) should last about 35seconds to 20 years dependant upon power up.. Sylvania 5Y3..about the same.. (Then again the 5Y3 is new so maybe it will last a bit longer)
M. Gregg
Old 12th June 2013, 04:45 PM   #15
Progress is slow..
Fitting it in around other things..
M. Gregg
Old 15th June 2013, 11:28 AM   #16
Some parts,
Arrived today...
I had to try the strange red astron just to find out what tin sounds like..
I have some same value jensens and others to try for fun..
Tx's on order..Hammond mains, edcor output..
Suppose I will have to do some more on it now..
M. Gregg
Old 15th June 2013, 03:20 PM   #17
Waiting for a harder coated input 1..(Phono)
M. Gregg
Old 17th June 2013, 05:07 PM   #18
More from the snail...
Power Tx arrived..
Its big enough to mod if I want to...hopefully it will run cool/quiet..
Vent holes drilled in base plate..
Just thinking about bases for the EF86's..I will use shrouded then I have the choice to use screening cans..I like the phenolic..But I'll get both.
M. Gregg
Old 21st June 2013, 09:32 PM   #19
Some more....
Started to build the input selector board.
Waiting for some more parts.
Just thinking about some mundorf tubecaps...however I have to wait for the OP Tx's from Edcor to check the space available.
M. Gregg
Old 30th June 2013, 10:31 PM   #20
Selector card completed,
I have some anti vibration mounts for the circuit board.
<<<still fitting it in... so its a bit slow..
I don't want to use PCB tracks so its silver wire link.
M. Gregg
OP Tx for signal tubes in Headphone amps M Gregg Tubes / Valves 5 24th May 2013 09:16 PM
OP Tx and PPP to PP change over M Gregg Tubes / Valves 3 30th April 2013 07:58 AM
Connecting Multiple op amp inputs from a single op amp output ZLyzen Analog Line Level 7 8th August 2012 12:17 PM
B+ TX. overkill? Richard Ellis Tubes / Valves 2 26th September 2006 09:12 AM
TX help for GC yuval Chip Amps 11 7th April 2004 08:41 PM
Copyright ©1999-2017 diyAudio
