6CB5 in triode PP? - Page 4 - diyAudio
Old 20th June 2013, 04:47 AM   #31
~88db.
40W or so is fine for casual listening, but anything with serious bass transients needs a brass pair to grip these bass drivers.
Old 20th June 2013, 05:02 AM   #32
jazbo8's Avatar
Nice looking OBs! What are the drivers? So the 6CB5 will drive the bass speakers?
I have only one Eminence Beta 15A per side, driven with a 100W Class D amp (shameful I know), perhaps it's time for an upgrade...
Old 20th June 2013, 05:06 AM   #33
AJT is offline AJT  Philippines
AJT's Avatar
Originally Posted by deicide67 View Post
He did by stating that the optimal load would be 2.54K, but 3.3K would suffice at the cost of a little power. 1.9K is less difference to 2.54K than 3.3K, so I am asking if it would be an OK plate load to use 1.9K vs. 2.54K.
Will the 1.9K load cause excessive distortion?
So, yes, miles did answer the question.
as a rule of thumb, i always prioritise SQ over power ratings.....
in your case i will choose 3.3k, you can connect the 8 ohm speaker to the 16 ohm tap is you wanted more power...
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 20th June 2013, 05:09 AM   #34
nope. They are fully passive and dynamic as almost any box speaker I've heard. The bass drivers are Acoustic Elegance IB15, midrange Peerless 830883, and the BG Neo3PDR with back cup removed for the tweeter.
I'm playing with the sweeps for fun because I cannot afford the tubes for my big amps yet
Old 20th June 2013, 05:13 AM   #35
I will see about the pricing difference between the Edcors and the guy with the Hammonds.
We will see. I'm actually curious about the sweep tubes. I've never tinkered with them before.
Old 20th June 2013, 05:13 AM   #36
jazbo8's Avatar
Cool! Let me know how the 6CB5 works out on the LF, I have not tried driving the bass on mine with a tube amp yet, since they require good control as you said.
Old 20th June 2013, 05:17 AM   #37
Don't feel shamed. I use a Emotiva 175W amp to drive my speakers right now. I'm looking for tubes that will nail my drivers with the same authority
My other project is a PPP KT120 amp. That should do it!
As for the 6CB5, I'm thinking that maybe I should go with monoblocks using PPP since I have two power transformers.
Again, speculative on the hammond pricing.
Old 20th June 2013, 05:19 AM   #38
AJT's Avatar
the OPT is the single most expensive item in an amp, getting bigger(heavier) than you need makes for better bass...
Old 20th June 2013, 05:24 AM   #39
I gotcha I've built a few amps, just nothing with sweeps. I'm familiar with output iron and cost/size/performance.
Old 20th June 2013, 05:34 AM   #40
AJT's Avatar
at a few dollars a pop what is not to like about sweep tubes?
though the 30 watters have moved up in price....
in my case i resist all temptations to build with hyped tubes, the costs are simply silly imho..
My EL84 Triode PP Amp sorenj07 Swap Meet 7 19th June 2008 05:13 PM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 01:22 PM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 01:36 AM
Triode strapping 6l6gc PP dionisio Tubes / Valves 5 24th March 2005 02:34 AM
Copyright 1999-2017 diyAudio
