6CB5 in triode PP?
6CB5 in triode PP?
Old 10th June 2013, 07:28 PM   #21
deicide67 is offline deicide67  United States
Something like this maybe?
No values because I don't know if these are the tubes I will use yet. I added the gain stage on the input in case the first triode of the 6GF7A is not sufficient. Should those stages be cap coupled?
Thanks!
Blair
Old 11th June 2013, 09:22 PM   #22
Does the 6GF7A I am proposing to use have enough voltage swing to drive a pair of 6CB5As to full output, or is a gain stage necessary to accomplish full output.
Something like a high powered "El Cheapo" with only three tubes.
Thanks!
Blair
Old 12th June 2013, 01:12 PM   #23
I have little fingers around the house, so I'm going to try to keep the top caps under the hood. There is adequate venting above and below the bulbs in this old chassis from a Proceed preamp. The Ecdors will fit in here as well as long as I stick with the 60W outputs.
You think I will need a "whisper fan" to circulate around the output tubes?
Is there enough room to build an amp in the chassis without too much crowding? This is one of the reasons I want to use the 6GF7A as a single tube driver.
Thanks!
Blair
Old 15th June 2013, 03:52 AM   #24
How much voltage swing is necessary to drive a pair of these 6CB5s? The 6GF7A is essentially a 13EM7 in a novar bottle. First section gain is 64 and second section is 5.4.
Will I need an additional gain section in front of these 6GF7As to get full drive voltage?
Thanks!
Blair
Old 20th June 2013, 02:02 AM   #25
Originally Posted by Miles Prower View Post
Forch, I saved all the original notes. Loadline (attached) Do keep in mind that this particular project never got built, so it's very much a preliminary design.
With an Rl= 635R/phase, you'll need ~2.54K (P-2-P) A 3K3, 60W Edcor should be just fine here, and the somewhat lighter plate load will drop the output a bit, and maybe the distortion as well (though it doesn't look like you're gonna get very much of that anyway).
Even though these H3 estimates are rough, and high-side errors, they do correlate somewhat to sonic performance. However, in the final analysis, you still have to spend some time listening to the open loop performance to see how that distortion sounds, and what's likely to be necessary to correct for those sonic defects. If the 6CB5 is like the 6BQ6, all it'll need is enough gNFB to take the "edge" off. There shouldn't be any of that "pentode nastiness".
I may have found a pair of 1650T Hammonds which are 1.9K and 120W. Is that way too low for a pair of the 6CB5 tubes?
Thanks,
Blair
Old 20th June 2013, 02:54 AM   #26
jazbo8 is offline jazbo8
jazbo8's Avatar
6CB5 in triode PP?
I thought Miles already answered all your questions on the drive requirement and the plate load.
Old 20th June 2013, 03:02 AM   #27
He did by stating that the optimal load would be 2.54K, but 3.3K would suffice at the cost of a little power. 1.9K is less difference to 2.54K than 3.3K, so I am asking if it would be an OK plate load to use 1.9K vs. 2.54K.
Will the 1.9K load cause excessive distortion?
So, yes, miles did answer the question.
Old 20th June 2013, 03:14 AM   #28
jazbo8's Avatar
6CB5 in triode PP?
No, the distortion would be a little bit higher but not what you would call excessive, especially at low-medium playback volume, fully crank'd, you will hear it - or not, as it would be so darn loud, you may have to cover your ears
Old 20th June 2013, 03:21 AM   #29
Thank you. That's what I'm asking more less. Assuming I can get the output iron at a good price.
If not, I will suck it up and wait 6 weeks for Edcor
Old 20th June 2013, 03:44 AM   #30
jazbo8's Avatar
6CB5 in triode PP?
Just curious, what speakers are you using, do they require all that power?
6CB5 in triode PP?Hide this!Advertise here!
My EL84 Triode PP Amp sorenj07 Swap Meet 7 19th June 2008 04:13 PM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 12:36 AM
Triode strapping 6l6gc PP dionisio Tubes / Valves 5 24th March 2005 01:34 AM
