Is this transformer saturation? (pictures inside) - diyAudio
Old 21st May 2013, 09:10 PM   #1
funk1980's Avatar
Default Is this transformer saturation? (pictures inside)
Trying to drive 4 KT88's connected to a Hammond 1650T to the max (120 Wrms rated), I saw this on my oscilloscoop. The 12AT7 LTP phase splitter has signal swing to spare (blue line), but the 4 ohm transformer tap shows the clipping yellow line, connected to a 4 ohm resistive load. Is this the saturation effect? Or is something else going on.
Old 21st May 2013, 09:43 PM   #2
DF96 is offline DF96  England
It looks like clipping. The output stage is running out of either voltage or current.
Old 21st May 2013, 10:00 PM   #3
MelB is offline MelB  Canada
What is your B+ voltage?
Old 21st May 2013, 10:08 PM   #4
funk1980's Avatar
It's 420 volts. The reason I think it's saturation, is because the Vpp is around 120W into 4 ohm. Would be too much of a coincidence. And a clipping LTP looks dufferent AFAIK. But I'm not shure.
Old 21st May 2013, 10:52 PM   #5
The LTP is not clipping. The output stage is clipping.
Old 21st May 2013, 11:06 PM   #6
The positive peak of the driver signal is flattening a bit. My guess is that you hit grid current on the output valves there. With mosfet source followers you could probably go into AB2 and get some more watts if you want.
Old 22nd May 2013, 04:52 AM   #7
Yvesm is offline Yvesm  France
Yvesm's Avatar
At such frequency (1Khz) the OPT CANNOT saturate !
It would be different below, say, 50 or 30 Hz.
As said above, tubes are probably running out of current or voltage.
I'm curious to see what happen in slghtly changing the load, f.e. from 3 to 5 Ohms.
Yves.
Old 22nd May 2013, 08:30 AM   #8
Miles Prower's Avatar
Flux density decreases as frequency increases. At 1000Hz, I wouldn't expect that to occur, at least not unless you hit insane volts/turns ratios somehow. Besides, saturation looks more like square waves.
It also looks like your driver doesn't have enough drive capability. The positive peaks are flattening, and that's what grid current looks like when you have inadequate current sourcing. You've taken the Vgk of the finals as far as you can go. Any farther, and you're in Class AB2.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 22nd May 2013, 09:19 AM   #9
Yes, the LTP is flattening a bit on one peak but that is not the cause of the output clipping. However, any more signal and the LTP would be the limit even if the output stage could cope.
For maximum possible output you want one side of the output to be hitting a voltage limit (bottoming) while the other side is at the current limit (cut-off) - they swap over at the opposite peak. This requires the right bias and right impedance load. For smoother clipping you want to avoid this, but at the expense of slightly less power.
Old 22nd May 2013, 10:21 AM   #10
funk1980's Avatar
But could it really be the output tubes/stage?? I mean, it's 420V into 4 KT88's with a 1900 ohm output transformer. Although the OPT is rated at 120Wrms, the KT88's should be capable of putting out way more than 120W!
Tonight, I'll replace the 12AT7 with an ECC99 I've got lying around. It's able to source more current than the AT7.
Preventing the inrush current saturation in a toroidal/EI transformer tauro0221 Power Supplies 111 14th September 2012 05:19 PM
What causes saturation in tubes? SpreadSpectrum Tubes / Valves 15 11th June 2010 11:32 PM
Transformer saturation & leakage Lucius Planars & Exotics 8 8th April 2007 08:14 PM
DC Saturation current of Transformer core coil? Mad_K Pass Labs 1 9th January 2004 06:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
