Who recognizes the chassis of this amp - diyAudio
Old 21st May 2013, 03:41 PM   #1
Default Who recognizes the chassis of this amp
Hello, I am Bert and live in the Netherlands, I did ask this question at the forum in the Netherland but I didn't got the right answere. Who can tell me what amplifier this is. The transformers, choke are made bij Thordarson. Hope you can help me,
Greetings Bert
Old 22nd May 2013, 01:19 AM   #2
Tom Bavis's Avatar
The 4-pin rectifer says "pre-war" to me, as Thordarson used octal rectifiers in the amps I've seen made from 1946 on. Though it's probably home built - the control marking doesn't look like a commercial product. They DID make a 1950 amp with two 6V6s, a 6SL7, and a rectifier, but it wouldn't have had two extra socket holes... List the transformer part numbers and I'll see what they fit...
Old 22nd May 2013, 01:37 AM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Heathkit, for comparison:
"Our youth [...] have bad manners, contempt for authority; they show disrespect for their elders, contradict their parents, [...] and tyrannize their teachers. -- Plato, 447-367 BCE
Old 22nd May 2013, 01:49 AM   #4
Wavebourn's Avatar
Leslie:
Old 22nd May 2013, 05:39 PM   #5
Hello Tom, the numbers on the transformers are 6754, 49C21, T40096 end T14C70. The former owners told me, that in the missing holes two tubes 2A3 were.
Greetings, Bert
Old 23rd May 2013, 01:11 AM   #6
Tom Bavis's Avatar
T14C70 is 22 Henry, 5 mA, "tone control" choke. The others may not be catalog parts - Thordarson started with "T", used "C" in the middle for choke, "S" for output, "R" for power, "F" for filament, "D" for driver.
Gutting an old amp to use chassis & output meters von Ah Solid State 5 10th August 2012 02:23 PM
Leach Amp (LS R & D) Chassis and Power Supply rss388 Solid State 2 1st May 2012 01:24 PM
Basic & Safe Case/Chassis for chip amp Baztien Construction Tips 16 13th April 2011 08:28 PM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 14th December 2007 11:41 PM
Anyone found easier amp chassis than these, allowing for time & price? rick57 Solid State 0 28th September 2005 12:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
