6922 preamp idea
6922 preamp idea
Old 15th May 2013, 12:54 AM   #1
RevMen is offline RevMen  United States
RevMen's Avatar
Default 6922 preamp idea
I would like to build a line stage preamp using a pair of 6922's and as few parts as possible. This is my second attempt at creating a circuit like this. I think I've got it, but of course it would be wise to get some more knowledgeable people to view it before I build it and subject it to high voltage.
So does this make sense, what I've done? I've attached the schematic and the load lines for both stages.
Old 15th May 2013, 01:10 AM   #2
kenpeter is offline kenpeter  United States
The grid voltage is usually lower than the cathode.
As you show loadlines with negative grid bias, I'm
assuming you knew what you were doing and must
have mixed up the drawing.
Old 15th May 2013, 02:02 AM   #3
RevMen's Avatar
Rookie mistake. Thanks for pointing that out.
121V should be 111V. That actually makes 27k the exact right value instead of the closest value, so that's good.
I've attached the fixed schematic.
Old 15th May 2013, 02:16 AM   #4
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
6922 preamp idea
you can read upon Broskie's CCDA......CCDA: constant-current-draw amplifier
i do no think you really need that high a B+, from 100 to 200 volts is plenty....better to keep the plate voltage at 90 volts max...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 15th May 2013, 05:16 AM   #5
Bonsai is offline Bonsai  Europe
Should this not be in the tubes section?
Old 15th May 2013, 09:54 AM   #6
TonyTecson's Avatar
6922 preamp idea
thread moved....
Old 15th May 2013, 10:37 AM   #7
Shoog is offline Shoog
Shoog's Avatar
I would replace the 16K resistor with a DN2540 configured as a CCS.
Shoog
6922 preamp ideaHide this!Advertise here!
my 6922 / E88CC preamp alexw88 Tubes / Valves 36 3rd September 2016 10:10 PM
6H30PI/6922 Preamp Circuit jonusgrumby Tubes / Valves 3 3rd December 2008 07:38 PM
5687 v.s. 6922 preamp/xover mashaffer Tubes / Valves 21 2nd May 2007 10:24 AM
