Tube SPDIF output
Tube SPDIF output
Old 31st December 2017, 02:11 PM   #31
Lowrideris is offline Lowrideris
Originally Posted by DF96 View Post
Rise time which is too fast can increase cable-related jitter.
do not agree, please study spdif protocol more closely, the faster signal rise, the less jitter is generated.plus dac is no more "quesing " it was 0 or 1,so data decoder is disbaling "data correction" algorithm
And ofcourse bad cable is bad in all situations, lets asume its good cable is used
Old 1st January 2018, 11:22 AM   #32
12E1 is offline 12E1  United Kingdom
12E1's Avatar
This assumes that the faster risetime is preserved throught the signal chain.
Unless the cable is correctly matched and terminated with a correct load impedance (or source impedance if serially terminated), if the driver risetime is too fast, then ringing will occur at the receiver end, and maybe at the driver. That ringing at the receiver could cause further timing errors which defeat the original objective of trying to ensure accurate timing.
The problem is that many people think of S/PDIF as a solely digital signal. In the final analysis, digital signals still obey the laws of physiscs, and they dictate that signals with fast risetimes need correct handling to preserve timing details and to avoid overshoot / ringing if they are significant to the application.
Old 1st January 2018, 03:06 PM   #33
DF96 is offline DF96  England
No data correction takes place after SPDIF, so nothing to 'disable'. All you get is parity, so you either use or discard the data. An SPDIF implementation would have to be very bad to corrupt the data so badly that it fails the parity check.
Too fast slew rate can give rise to greater cable-related jitter, as I said. The details depend on things like cable length and how resistive the termination is at all frequencies. Basically, if you put a faster slew rate in then you must hope that the terminations remain correct up to higher frequencies. Obviously too low a slew rate causes trouble for the receiver data slicer.
Old 2nd January 2018, 07:34 PM   #34
316a is offline 316a  England
316a's Avatar
What next ? A tubed I2S buffer ?
316a
Tube SPDIF outputHide this!Advertise here!
SPDIF OUTPUT kawo Digital Source 96 17th June 2011 05:49 AM
SPDIF Output Korr Digital Line Level 8 25th February 2011 10:02 AM
CS8416 SPDIF Output AMR Digital Source 0 7th January 2011 06:15 PM
SPDIF output PCB kawo Digital Source 19 13th November 2010 02:29 PM
HELP! Quartet spdif output ichiban Digital Line Level 2 21st August 2009 07:45 AM
