4tube Philco amp project...
Old 20th May 2013, 11:49 AM   #31
knockbill is offline knockbill  United States
knockbill's Avatar
Originally Posted by Eli Duttman View Post
There are 2 openings for controls in the chassis. Put a mono volume control in each opening. C6, C10, and R9 (A/B) constitute what passes for a stereo tone control. All those parts are capable of doing is rolling HF info. off. In short, they are GUANO. Remove means exactly that; excise those parts, for being the "cancer" that they are. C3/R2 and C4/R3 are frequency shaping networks that boost HF info. Those parts are "cancer" too and need to be removed. The less the I/P signal is "massaged", the better. That's HIFI.
Forget what I said about additional fixed resistance in series with the controls. Just use a pair of 1 MOhm mono pots. and connect them directly to the I/P signal wires.
Mouser stocks low cost Alpha Taiwan controls. Look here. You want audio, AKA log., taper parts. Your local "Rat Shack" may be a source too.
Thanks for the info,,, seems there is a lot more parts in here then need be,,,I think I got it now,,, remove the original tone pots and VC pots, and replace w/2 one meg audio pots, which will act as VC/Balance.... also remove the C & R associated with them...
I have to order some caps for the Motorola this morning, I'll get the pots also...
I appreciate all the time you've spent, tutoring me, as I'm sure all the other forum members you consistently help do also....
John
4tube Philco amp project...Hide this!Advertise here!
Philco F-1801 TexasAudio Tubes / Valves 0 8th February 2012 01:56 AM
Cap Problem with philco 49-1401 gto127 Tubes / Valves 16 11th June 2011 02:40 AM
1946 philco amp, tuner, record player tryonziess Tubes / Valves 2 26th May 2010 01:29 AM
Interesting old Philco electrostatic tweeter peace brainerd Multi-Way 0 8th March 2010 10:56 PM
1946 Philco Tube Receiver tryonziess Tubes / Valves 18 1st February 2010 11:54 AM
