This is schematic for my new PP with GU50. Max power more than 100W, THD at 80W 0.55%. I plan to build that amp in next few mounths. All voltages other than 700V will be regulated.
Ask for comments. |
#2 |
mostly thinkerer
Hi, I think it would be good to leave some more headroom for the source followers. With headroom I mean a bit more than the +20V (maybe +100V) and possibly more negative voltage as well (more than -100V, and larger resistor). The reason is that the capacitances of mosfets are not very linear when VDS becomes small, so it is better to have at least 30V VDS under all circumstances.
I think your definitive amplifier will have independent voltage sources (pots) for bias adjustments, to compensate for differences between GU50's? have you looked into the 'bestpentode' connection for the input stage? I do not know if it works together with the local feedback arrangement, but I think it will. It could give a bit more gain, less noise, and possibly better balance in the LTP.
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
#3 |
Good luck! :-)
Please come back when you get some results, and I will share my Pyramid experiences. And probably PCBs. :-)
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#4 |
IRFP240 as followers at 90 mA? Surely not - there are far better suited MOSFETs, IRFP240 has WAY too much capacitance, and this will be extremely nonlinear as Vgd approaches 8-10V. Even at 100mA per follower (which seems a bit excessive but I am guessing you are trying to make the change in current lower as the G1 of the GU50 goes positive) there are better (smaller) MOSFETs to use, also a bit more voltage on the current 20V supply...
#5 |
#6 | |
#7 |
I think your design lacks the possibility of adjusting the GU50's bias, doesn't it?
Best regards! |
#8 |
As I wrote before - this is working schematic for LTSpice. I always do bias like this:
#9 | |
it will be more comfortable to use two potmeters , one for the bias balance and another to set the idle current, like this example: 73 Wolfgang
Ground your devices before they ground you |
#10 |
I prefer this circuit: http://www.diyaudio.com/forums/attac...s-kt88_amp.png No matter which trimpot fails the bias voltage will go full negative and switch-off the tubes. No, I am not kruesi...but i use the same bias circuit for my amps. regards |
| Chinese GU50 PP | wazza220951 | Tubes / Valves | 47 | 18th October 2012 08:01 PM |
| Help~ GU50 ? | maxxtro | Tubes / Valves | 3 | 2nd October 2012 07:01 PM |
| PP GU50 triode strapped project | FrançoisL. | Tubes / Valves | 63 | 27th July 2012 10:33 AM |
| OPT PP for GU50 Triode ? | pwan | Tubes / Valves | 0 | 12th March 2011 11:30 PM |
| Gu50 | cristelu2006 | Tubes / Valves | 13 | 18th November 2009 10:29 PM |
