6A5G schematic; changes from the 6Y6G tube
Old 29th April 2013, 09:02 AM   #1
pianolydia is offline pianolydia  United States
Default 6A5G schematic; changes from the 6Y6G tube
Hi All,
This schematic now has been edited to reflect some changes made, as to the New tube 6A5G Output Triode instead of the 6Y6G. What do you think now?
This seems better to work I think..... Lydia
Old 29th April 2013, 05:55 PM   #2
kevinkr's Avatar
Cool it guys or you'll both spend a week in read only mode for posts that violate a number of diyAudio rules.
Pianolydia having looked at a number of your threads questions do arise, I recommend you pick up a few books and do a little reading. One excellent book I strongly recommend is Morgan Jones' "Valve Amplifiers" 4th edition. The "Building Valve Amplifiers" book by the same author is also a worthwhile read.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
6A5G schematic; changes from the 6Y6G tubeHide this!Advertise here!
6Y6G SE SCHEMATIC NEEDING HELP! pianolydia Tubes / Valves 1 29th April 2013 06:44 AM
6Y6G tube for low-voltage SE amplifier? KrankKall Tubes / Valves 7 13th July 2011 02:56 PM
Simple Tube Mono Block Tube Amp Schematic jleaman Tubes / Valves 16 24th November 2009 08:42 PM
need tube schematic xazopartalos Tubes / Valves 3 21st October 2007 09:21 AM
Where to buy 6A5G ? RCA245 Tubes / Valves 5 19th August 2006 06:44 AM
