6Y6G SE SCHEMATIC NEEDING HELP! - diyAudio
Old 29th April 2013, 06:18 AM   #1
Default 6Y6G SE SCHEMATIC NEEDING HELP!
Hi All, Just need help in Evaluation to make this amplifier work!
What do you see that needs to be corrected? Are these values going to work?
and Will I be able to use these valves in this setting? Any Info would be Appreciated!
very much! The 500 ohm primary and 1 ohm secondary of the output transformer
I believe is a DC Resistance reading.... What about a 6A5G? Lydia
Old 29th April 2013, 06:44 AM   #2
tricomp is offline tricomp  Denmark
Lydia,
Sorry to say that your schematic is so full of errors that it's not going to make any sense trying to explain here what you did wrong.
Some errors are so basic, that if you don't immediately see them, like the negative-supply rectifier being the wrong way around, I would suggest that you keep off 300V circuits.
It just takes a bit more knowledge to start messing around with tube-circuits.
rgds,
/tri-comp
PS.
Don't you find it odd that the two 6Y6 symbols are drawn differently?
One as a pentode and the other as a triode.
Since it is a pentode it's going to miss some screen-grid feed in your circuit.
Also read-up on what current a control-grid (Grid-1) should draw. 90mA is a bit much
Yamaha RX V496 - i am needing the schematic destroyer X Solid State 8 4th January 2014 08:38 PM
Needing Schematic for Grommes LJ7 please. Goldstache Tubes / Valves 0 7th October 2012 11:25 PM
6Y6G tube for low-voltage SE amplifier? KrankKall Tubes / Valves 7 13th July 2011 02:56 PM
needing schematic of amplifier of mic ary Multi-Way 3 16th September 2005 12:28 AM
se 6c33c or se el34 schematic karma Tubes / Valves 10 2nd July 2005 05:40 PM
Copyright 1999-2017 diyAudio
