Micro amp - all-tube, direct heated, portable and IT FITS
Old 26th April 2013, 10:28 PM   #1
dovla is offline dovla
Default Micro amp - all-tube, direct heated, portable and IT FITS
After almost going blind soldering everything and stuffing it into an impossibly inappropriate mint box here is a battery powered headphone amp sounding surprisingly good for the size of OPTs.
Everything runs off one battery and it plays decent 9 hours on one charge when using 3400 mAh cell (B+ set at 27V).
Component values were set by listening exclusively since I have no scope (aiming for slightly more gain then smartphone directly to headphones) so proper measurements would probably lead to some other choices but the way it sounds now more than surpassed the expectations.
Other than the tubes and resistors everything was recycled so monstrously looking coupling caps (which look tiny in grown-up amps) are there just because they happened to be present at construction time. I also regretted this decision as used components don't like being soldered again, to which burn marks on the insulation can testify.
Old 26th April 2013, 10:34 PM   #2
Default + schematic
And schematic attached as well. There was uneven gain between the two 1zh29b tubes and that was sorted by different screen resistors (one channel 20K, the other 12K). The picture shows how the values were chosen
Old 27th April 2013, 12:00 AM   #3
lexx21 is offline lexx21  United States
Very cool build. I can easily see how you would go cross eyed building that. Nice job.
Old 27th April 2013, 08:23 AM   #4
andyjevans is offline andyjevans  United Kingdom
I can see arguments for and against you as a brain surgeon....
Old 27th April 2013, 11:16 AM   #5
JLH is offline JLH  United States
JLH's Avatar
That's great stuff. I love seeing people build things like this. It's nice seeing different things.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 27th April 2013, 11:57 AM   #6
Default Airport safe
Even though it clearly says on top cover what the device does ("for throat AND VOICE") I still have to give myself some extra time when traveling.
So far the record for is held by Heathrow airport - 3 security screeners, 3 armed policemen and 2 special branch agents were deliberating for 20 minutes before one remembered to ask me what it was (another dismal statistic - none of them could recognized Manu Chao playing - never heard of him, to be precise)
On the bright side, one of the security personnel in Munich asked where to buy an amp like this.
Old 27th April 2013, 02:33 PM   #7
TheGimp is offline TheGimp  United States
TheGimp's Avatar
That is Great!
Reminds me of all of the transistor projects I did in Sucrets Throat Lozenges Tins.
Micro amp - all-tube, direct heated, portable and IT FITSHide this!Advertise here!
Direct heated tubes with centre tap on filament mig-ru Tubes / Valves 21 15th August 2017 07:01 PM
What is the theoretical advantage of direct heated triodes? cotdt Tubes / Valves 205 5th February 2013 10:13 AM
1AG4 Direct Heated Pentode, Output TheGimp Tubes / Valves 11 18th February 2012 10:19 PM
sub micro tubes for a portable headphone amp dBel84 Headphone Systems 3 21st March 2010 05:01 AM
Best low-signal direct heated triodes? gentlevoice Tubes / Valves 7 5th May 2008 04:03 AM
