breadboard for tubes
Old 24th April 2013, 09:34 PM   #1
morelius is offline morelius  Spain
Default breadboard for tubes
This is my fist post in this forum. I'm new the tube and i want make a breadboard for learn. can you recommend me a system of protoboard?
Thanks for all information and answers
Old 25th April 2013, 12:29 AM   #2
Astera is offline Astera  United States
I'm not aware of one. I've built my own bread-board like components though.
Old 25th April 2013, 12:40 AM   #3
Printer2 is offline Printer2  Canada
Something like this?
Click the image to open in full size.Notice that high voltage potential points are separated by 2 or 3 rows. I also use a metal plate under the the plywood that I ground, gets rid of most of the hum.
Old 25th April 2013, 01:12 AM   #4
Tubelab_com is online now Tubelab_com  United States
Tubelab_com's Avatar
I have made several different breadboarding systems over the years. Two are shown in the link. They both require considerable bench space, which limits their use in my smapp lab.
The Tubelab
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 25th April 2013, 02:58 AM   #5
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I built the second version in the tubelab link, with the plastic perfboard and will attest to it taking up room.
But, it's nice.
Old 25th April 2013, 04:01 AM   #6
Yeah, mine look a little like the Tubelab set-up ... with Fahnestock clips.
I made them little modules, but the more I've used it, the more I realize there are not too many amp topologies. You could almost lay out a SE or PP amp with Fahnestock clips for the various caps (coupling, etc.) and resistors (grid, etc.) that hang around.
Old 25th April 2013, 04:15 AM   #7
avincenty is offline avincenty  United States
This is the first thing i built to start learning about tubes.
Old 25th April 2013, 06:20 AM   #8
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Nice lab Avincenty, can you share more detail and pics?
Cheers
If you keep digging in the garden of failure you will eventually find success
Old 25th April 2013, 08:29 AM   #9
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
Over the last years I worked on a 'tweaker friendly amplifier'. Besides prototyping (allowing easy exchange of smaller and larger components) I was looking for a system that can also work quite well and safely after prototyping/tweaking is done (so one doesn't need a prototyped amp on a 1D breadboard to a final chassis). I like working with hybrids or sand assisted PS, so I included large L profiles that act as side panels as well as heatsinks, and more heatsinks can be added to the top op the amp if needed.
Meanwhile I had a lot of new ideas, but will have to wait until I am back from Maputo, Mozambique to test them out.
The thread http://www.diyaudio.com/forums/tubes...amplifier.html
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 25th April 2013, 12:19 PM   #10
Cheers
I dont have details of the build. The 4 meters are: 1 250ma, 1 200v and 2 500v. I put these since a few of my HV supplies do not have built in metering. 1/2 of the 9 pin sockets have share the same heater voltage. The 8 pins and the other 1/2 of the 9 pins share another.
Initially i labled the 9 pins for the 12ax7 pinout. I later numbered the jacks so i could use any other pinout.
I added another breadboard for flexibility, i also use it to test solid state stuff.
I also purchased from craigslist a HK A300 and thoroughly went through it with voltmeters and oscilloscope. Learned a lot doing it.
Very important was obtaining the power supplies. Luckily i was living in LA at the time and found vintage gear for 20 a pop.
From there i tested A PP configuration and played with tone controls. My first build soon after that is the larger tube amp in the middle shelf. The HK A300 is below.
breadboard for tubesHide this!Advertise here!
Anyone know where to get this type of breadboard? ottopilot Tubes / Valves 7 27th September 2012 01:48 PM
Breadboard Class D!! nitrate Class D 218 12th September 2011 04:04 PM
Breadboard help g(f(e)) Tubes / Valves 4 23rd December 2010 08:38 PM
IRS2092 on breadboard rob mullen Class D 31 27th November 2010 12:24 AM
Breadboard 6C33C-B S.E.T Alastair E Tubes / Valves 3 26th April 2005 07:59 PM
