breadboard for tubes - Page 2 - diyAudio
Old 25th April 2013, 06:42 PM   #11
hi,
I'm very happy for the information, thanks. I think now which is the best option for me but i find very interesant the option of tubelab with the individual modules.
Old 25th April 2013, 07:24 PM   #12
tomchr is offline tomchr  Canada
tomchr's Avatar
I've used a "peg board" made from a piece of plywood and some brass nails for prototyping. That's a bit of a pain to work with, though. My favorite is a scrap piece of FR-4 PCB material with holes drilled in it for the tubes. I use some terminal strips for connecting components. That works well enough to allow me to debug the circuit before committing to a PCB layout.
You can see examples of both methods here:
6LU8 Spud - Request for comments
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 25th April 2013, 11:53 PM   #13
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
I dont have details of the build. The 4 meters are: 1 250ma, 1 200v and 2 500v. I put these since a few of my HV supplies do not have built in metering. 1/2 of the 9 pin sockets have share the same heater voltage. The 8 pins and the other 1/2 of the 9 pins share another.
Initially i labled the 9 pins for the 12ax7 pinout. I later numbered the jacks so i could use any other pinout.
I added another breadboard for flexibility, i also use it to test solid state stuff.
I think this is a great idea, compact, with space to add more
Any chance you could post a top and internal view?
Cheers
If you keep digging in the garden of failure you will eventually find success
Old 26th April 2013, 12:51 AM   #14
I have been away from my lab a few months now, Lab is in the west coast, i am on the east coast with a new job. The pictures are 5 years old, never took a underside picture. Will go back to LA in a few weeks to pack, will try to get an underside shot.
Old 26th April 2013, 01:30 AM   #15
Dagwood's Avatar
Awesome, might kind of copy this if you dont mind
Old 26th April 2013, 03:12 AM   #16
AlanL is offline AlanL  United States
Our friend Pete Millett offers some handy tube sockets for breadboarding
pmillett | eBay
Old 28th April 2013, 04:37 PM   #17
I've used prototyping pcb boards sold on Ebay by various Chinese sellers. You can find them by searching "prototyping pcb board tube".
They have footprints for several 7, 8 or 9 pin tube sockets, size 150x200mm barely enough to assemble all the power push-pull amplifier stuff, thickness 1.6mm makes them too flexible and fragile to cracking.
Images of prototyping boards with KT88 Williamson ans floating paraphase /push-pull attached.
Extra terminals soldered on board used to switch between penthode, UL, triode and CFB modes, turn GNFB on and off, and attenuating RC networks. Very handy to tweak and debug amplifier.
Anyone know where to get this type of breadboard? ottopilot Tubes / Valves 7 27th September 2012 01:48 PM
Breadboard Class D!! nitrate Class D 218 12th September 2011 04:04 PM
Breadboard help g(f(e)) Tubes / Valves 4 23rd December 2010 08:38 PM
IRS2092 on breadboard rob mullen Class D 31 27th November 2010 12:24 AM
Breadboard 6C33C-B S.E.T Alastair E Tubes / Valves 3 26th April 2005 07:59 PM
Copyright 1999-2017 diyAudio
