ECC88 mu-follower
ECC88 mu-follower
Old 22nd April 2013, 12:53 PM   #1
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default ECC88 mu-follower
Hey guys, I need to know the output impedance of the attached schematic.
TIA
Felipe
Old 22nd April 2013, 01:01 PM   #2
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi!
Sometimes a little googling helps and you find pages like these:
Thomas
http://vinylsavor.blogspot.com/
Old 22nd April 2013, 01:42 PM   #3
DF96 is offline DF96  England
I would not trust the calculations on that site. He doesn't seem to have understood how SRPP actually works.
For some understanding try Merlin Blencowe's site - the valve wizard.
Old 22nd April 2013, 02:10 PM   #4
Plese who knows the output impedance?
Old 22nd April 2013, 02:16 PM   #5
The original designer?
To calculate the output impedance you need to know the valve operating point so you can find the mu and ra. Then plug these into the formula which Merlin gives on his site.
Then remember that output impedance and optimum load impedance are not the same thing so be clear what you actually want to know.
Old 22nd April 2013, 02:32 PM   #6
Vinylsavor's Avatar
Hi!
Or just build it and measure it. Should be a quick job to breadboard such a circuit
Thomas
Old 22nd April 2013, 02:33 PM   #7
euro21 is offline euro21  Hungary
ECC88 mu-follower
LTSpice sim: about 400R (at 1kHz)
Old 22nd April 2013, 02:39 PM   #8
Thank you, Thomas link: platten spieler calculator sim about 321 ohms, can be good for 300 ohms load?
Old 22nd April 2013, 02:45 PM   #9
ruffrecords is offline ruffrecords  United Kingdom
ruffrecords's Avatar
No, output impedance is no indicator of drive capability. As a rule the load should be no less than 10 times the output impedance.
Cheers
Ian
Old 22nd April 2013, 02:47 PM   #10
You are welcome Ian, how can change something of schematics posted in the 1st post to increase drive capability for 300 ohms load?
ECC88 mu-followerHide this!Advertise here!
cathode follower ecc88 on 60volt milosus Tubes / Valves 14 31st August 2012 01:30 PM
Half-mu stage (or SRPP) w/6DJ8/6922/ECC88 tubes at Low B+ voltage? Mateo Jun Tubes / Valves 1 15th March 2012 04:12 AM
Mu follower MrCurwen Tubes / Valves 3 13th April 2011 11:46 AM
MU follower - distortion Brit01 Tubes / Valves 25 27th August 2010 11:44 PM
6DJ8/ECC88 mu-follower SSassen Tubes / Valves 30 11th April 2007 08:19 PM
