Oh! Darling
Oh! Darling
Old 22nd April 2013, 04:40 AM   #1
Astera is offline Astera  United States
Default Oh! Darling
I hand-wired about three Darling tube amps a few years back and decided to revisit the design. I had my fill of point to point so decided to lay out a PCB.
Here is Oh! Darling:
I built two now ... into rather poor enclosures. But they sound awesome.
Thanks to the community that have shared the Darling design.
For the office or a relaxing evening in the living room, these amps are hard to beat.
Old 22nd April 2013, 05:33 AM   #2
tomchr is offline tomchr  Canada
tomchr's Avatar
Schematic?
Nice, tight PCB.
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 22nd April 2013, 02:14 PM   #3
Schematic is the vanilla 1626 Darling schematic floating around. I've seen one from 2005 attributed to Tom McNally.
The PCB went through a couple iterations to get where it is. Finally I was able to get it under 21 square inches to qualify for a discount on board pricing. (The board contains PS circuitry and I wanted the caps lying on their sides ... so that made it a challenge.)
For low power amps like the Darling, I like PCB's. Primarily I guess because of how clean they look and how quickly you can stuff the boards.
I had a hand-wired push-pull go south on me and the prospect of "detangling" it in order to diagnose/repair it was daunting. I just wanted to do a "board swap" and be done with it.
Old 22nd April 2013, 03:31 PM   #4
Palustris is offline Palustris  United States
Palustris's Avatar
The "Darling" 1626 amplifier was designed by Bob Danielak in the late 1990s. The design was published in Sound Practices Magazine issue 15.
Old 22nd April 2013, 03:53 PM   #5
MikeR is offline MikeR  United States
I built one about a year ago using the DIYTUBE board. It uses a single 12SL7 as a driver. Your board is considerably smaller.
You are right that these are fun little amps. I have mine at my work bench with a cheap pair of Radio Shack full range speakers placed only a few feet from my head so, little power is required. I feed it with my iPhone. Not the last word in hi-fidelity but fun for sure. And the tubes are cheap.
Old 22nd April 2013, 04:34 PM   #6
tomchr's Avatar
Be careful that the electrolytics by the standoffs in the corners don't short to the standoffs. Depending on the amount of clearance, you might want to give them a piece of Kapton tape. The exposed metal on the top of those 'lytics is connected to the negative terminal of the cap.
Another approach would have been to place the tube sockets on the bottom layer - like you did with the terminal blocks. Components on top, tubes on bottom. Then, once assembled, flip the assembly to let the tubes poke out of the chassis. Your layout is more compact, though. I like it...
~Tom
Old 22nd April 2013, 06:42 PM   #7
I forgot to thank those that contributed to the Clementine amp as well: there were a lot of good ideas in the (Darling) Clementine as well.
@MikeR: Yeah, full-range are nice. I threw on a sub though to pick up the bottom end a bit.
@tomchr: Thanks, I do worry about components too close to the stand-offs. In fact there's 3/16" to 1/4" though. I'll have to see what this Kapton tape is though — sounds useful. Thanks.
Old 22nd April 2013, 07:13 PM   #8
tomchr's Avatar
Kapton tape can tolerate extreme temperatures (-100 to +500 F; -73 to +260 C) and has a high dielectric breakdown strength (typ. 7 kV). It's very handy for applications where you need electrical isolation and need the tape to remain in place even at elevated temperatures. As you can guess from the specs, it's also rather pricey. But having a short roll of 1/2" wide Kapton (link below) available is handy at times.
1/2-5-5413 3M (TC) | 3M10235-ND | DigiKey
But with 3/16"~1/4" from the end of the 'lytic can to the metal standoff, you probably don't have anything to worry about in this particular circuit. It looks much closer, though. Especially in the front right corner of the board pictured above. Another approach is to get 'lytic cans that have a plastic disc on the top isolating the can from the outside world.
~Tom
Old 23rd April 2013, 01:03 AM   #9
@tomchr: You're right, I didn't have the board in front of me when I claimed 3/16". Now that I have it with me, it's a shy 1/8" for the front stand-offs (the other stand-offs are not a problem). I may try slipping a short length of vinyl tubing around the stand-off as well....
Old 23rd April 2013, 06:27 AM   #10
tomchr's Avatar
That'll work. Or heat shrink tubing.
Oh! DarlingHide this!Advertise here!
Darling 1626 xecluded Tubes / Valves 9 14th May 2012 09:03 PM
My DC Darling MrCurwen Tubes / Valves 7 5th August 2010 08:54 PM
Darling monoblocks Greyskale Tubes / Valves 3 13th March 2008 11:25 PM
Problem with my Darling! philipbarrett Tubes / Valves 58 7th March 2005 03:59 PM
My darling is giving me hell! Bas Horneman Tubes / Valves 16 1st June 2004 08:00 AM
