Old 30th November 2003, 11:23 PM   #11
diyAudio Senior Member
fdegrove's Avatar
It just takes a lot more resisitors.
No technical reason it should though...
Frank
Old 30th November 2003, 11:38 PM   #12
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
Hi Variac,
I had seen this board, but not considered it, since I wanted balanced inputs / outputs and two of these boards wit the resistor pack is $280 (£162.39) !!! If I use single ended (as I always have in the past) it brings it down to a much more managable $140 (£81.19).
However, since this is only attenuation, I feel that I need some kind of gain stage, which brings us back to the original question...
What is a good small gain stage (read cheap yet audiophile ) for this system?
Thanks,
Gaz
Old 30th November 2003, 11:42 PM   #13
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Have you searched...for e.x: Simple Fet-Buffer or something similar?
BoSoZ (Balanced Line Stage) is also a cheaper/simpler option to Aleph P
Arne K
Ars longa, vita brevis
Old 1st December 2003, 12:04 AM   #14
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
With P 1.7 the Apox is recommended to be used after the preamp stage (at the output) and this is mainly what it was (Apox) designed for.
You might consider maybe trying this High-end preamp for my GC
It's as simple as chip preamp comes and supposedly sounds good (although I don't really believe it)
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st December 2003, 12:10 AM   #15
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Yeah, that's why I don't have them!
I second the BoSoZ, that's what most people around here use.(well maybe not in the Tubes forum but certainly over in the Pass forum )
Old 1st December 2003, 02:54 AM   #16
hi rarkov,
if you need a buffer with low voltage, the circuit of figure 16a in http://www.borbelyaudio.com/ae699bor.pdf should be a good choice for you, when you connect your GC in inverting mode, you will need 2 of this buffer, one before APOX 2 and one after.
DAC-->buffer-->APOX 2-->buffer-->GC
leo
Old 1st December 2003, 09:22 PM   #17
Rarkov's Avatar
I was reading through my AudioXpress mags to try and get some inspiration. It suddenly dawned on me that I had wanted to try the "Line Stage Odyssey" described in the feb and march 2003 issues. It is a transformer output line stage "with parafeed taking it to the ultimate".
It does look very compact yet appealing design. The author (as expected) raves about the quality of the line stage module.
Has anyone any thoughts on the compatability of these? It does say in the article that a volume pot / attenuator should go before the module, which is a direct conflict with what Peter has been saying. Peter?
Thanks,
Gaz
Old 1st December 2003, 09:26 PM   #18
It is not in conflict with anything. I've built BOZ and was using pot at the input, but it is recommended to use it at the output as it attenuates the noise coming from that preamp.
It is dependant on the design and pot can be placed both before and after an active module. It's just in some cases it works better one way than the other.
But I also like to use pot directly at the input of the active stage.
www.audiosector.com
Old 1st December 2003, 09:39 PM   #19
Rarkov's Avatar
OK, sorry, got my wires crossed then. So in this case, would you suggest putting the tube module before or after the apox attenuator? I assume you have seen the article I'm referring to?
Thanks,
Gaz
Old 1st December 2003, 09:51 PM   #20
I'm not familiar with the article and maybe some tube guys can suggest better.
The Apox SHM doesn't provide constant input impedance, so using it at the input might be questionable. However, when high resistor values are used it might be possible. Using it at the output (providing resistance is low) whould probably be a better solution anyway. But my experience with Apox is too limited to provide satisfying enough info. Try to contact Dale and ask him. The rumor is they work on a budget version of a system, so maybe this would be something more suitable for you.
www.audiosector.com
how do i add volume control to a preamp merickrc Chip Amps 0 23rd March 2009 02:02 AM
X-preamp volume control MBK Pass Labs 45 3rd July 2008 09:14 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
Preamp volume control?? Craig405 Tubes / Valves 7 10th September 2005 10:32 AM
Another APOX volume control project tiroth Solid State 17 30th March 2004 08:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
