heathkit SA2 - diyAudio
Old 19th April 2013, 02:49 PM   #1
rock12 is offline rock12  United States
Default heathkit SA2
Recently rebuilt a heathkit SA2 using there detailed manual( they even tell you how long to cut and where to bend every wire). New caps and resitors were installed. I used the hum trim pots but there still remains some hum how do I trace this down? I own a digital meter and soldering iron
Old 19th April 2013, 03:07 PM   #2
rmyauck is offline rmyauck  Canada
Is that a before pic, as the round orange item looks like a original cap? What about the topside can caps(s)?
Old 19th April 2013, 03:42 PM   #3
DF96 is offline DF96  England
Check the heater wiring for really tight twists and small loops, especially near the input stages. The part shown in the photo doesn't look brilliant.
Old 19th April 2013, 03:53 PM   #4
trobbins's Avatar
Localising the source/cause is important - as many red herrings can be suggested as a solution.
Try and check if it is just from the input stage (short the signal or turn down a pot after the input stage). Try and check if it isn't the input stage input wiring (short the input valve grid to 0V). Run the input stage heater from a battery (this will indicate if it is heater related).
Old 20th April 2013, 01:33 AM   #5
ALL electrolytic caps. must replaced. The orange "thingy" a previous poster pointed at looks like a 'lytic to me. Jim McShane is a good source for tubes, parts, and advice. The can cap. previously mentioned is (IMO) best replaced by a clamp mounted part occupying that opening. Mr. McShane stocks that sort of stuff.
What, if any, source was used, when the hum was detected? You need shorting plugs in the I/P jacks to test, without a signal source being attached.
Take a close look at the schematic. Notice AC heating in the phono section. Only a 7025 equivalent, with its spiral wound, hum bucking, heater, has a ghost of a chance of being quiet enough. Buy a pair of phono grade, current production, Sovtek 12AX7LPS tubes from McShane. That Saratov, Russia, made variant IS a genuine 7025 equivalent, whose price is reasonable too.
Heath's gain structure is wretched! They attenuate line level signals and then amplify them with the 2nd gain block of the phono section. That wreaks havoc with the S/N ratio. That can be "cured" by replacing the source selector switch with an inexpensive Lorlin brand part from Mouser and a bit of rewiring.
The "laundry list" goes on. Install a proper, 3 wire, safety grounded, power cord. Get "120" VAC away from the front panel by disconnecting the on off switch on the treble control. Install either a slide or rocker switch in an opening currently occupied by a convenience outlet, to control the on/off function. Add the uploaded SS diode tweak to the 5AR4 socket, with UF4007s, not noisy 1N4007s. The tweak may allow you to squeeze some extra time out of the old stock tube and is essential to reliable operation of the current production Sovtek 5AR4, which is the best of the affordable stock. NOS 5AR4s are outrageously expensive.
BTW, if you plan on recording LPs to another medium, a much more capable phono section, whose O/P impedance is low, is needed. Yes, I have a candidate for that job, should it be needed.
Eli D.
Old 20th April 2013, 11:43 AM   #6
Sorry should have labeled the picture as a before pic. Thanks for the advise it was a great project to learn from. I will try some changes and get back
heathkit SA2 rock12 Tubes / Valves 4 6th June 2012 11:53 AM
Heathkit variac ixe13 Tubes / Valves 3 3rd April 2008 05:01 AM
heathkit sa2 - new question -=Zepplock=- Tubes / Valves 8 5th September 2006 05:29 PM
Perreaux sa2 laz Solid State 3 26th February 2004 11:12 AM
Copyright 1999-2017 diyAudio
