Accident - Shorted Cathode to grid!!
Old 17th April 2013, 11:46 AM   #1
surfstu is offline surfstu  United Kingdom
Default Accident - Shorted Cathode to grid!!
Feel like a fool,
Was probing voltages in my amp and I accidently swiped the probe across pin 2 and pin 3 causing a short and a serious amount of hum.
The hum remains! That channel is now just giving me a little music and a lot of hum, I hope i have not damaged the transformer.
I am aware that I have shorted the screen of the pentode to the cathode of the triode which is fed by ccs....
Can anyone shine some light on what I have done?
S
Old 17th April 2013, 11:56 AM   #2
Mooly's Avatar
Check the DC voltages on the current sink. Is the LED lit ? You should have around 1.2 volts across the 1K. The semiconductors are the parts most likely to have been damaged.
Edit... voltage across the lower 1K that goes to the emitter
Old 17th April 2013, 11:57 AM   #3
So, I have just measured the voltage at pin 2 (with a crocodile clip!!) where the CCS meets the cathode and it is 9V on the side that i shorted.
It is 4 V on the otherside of the pair (same channel)
This was always 1.5 V on each side of the diff amp pair...
Could I have blown a transistor in the CCS supply?
S
Old 17th April 2013, 12:00 PM   #4
Thanks Mooly, the other channel appears unharmed
I will swap the CCS over and see if it works, then I guess I will know that it is the CCS supply that has blown!!
S
Old 17th April 2013, 12:04 PM   #5
Mooly's Avatar
All the evidence will be there in the voltage readings but yes, you have probably zapped one of both transistors.
Old 17th April 2013, 12:26 PM   #6
Yep, channel workes fine now that i have swapped the CCS supply over from the other channel.... yes both LED's are lit.... I will go buy another pair of transistors!h
Old 17th April 2013, 10:09 PM   #7
Unbelievable!! So I ran up my electronics store and bought 2 new bc547b's for the CCS. Spent a good deal of time undoing my work and finally replaced them, only to find that I still had a problem... it turned out the short had wiped out my 220R pot that I used to adjust the CCS delivery to the two tridoes...
Am learning never to assume, I should have checked the voltage all the way back to the CCS!
Getting there slowly...
S
Old 17th April 2013, 10:27 PM   #8
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
I HIGHLY recommend checking all the resistors ... the 470Rs, etc.
Dumping the HV into the cathode leg can short 'em all out.
They're probably film, and I've found that unlike "old fashioned" bulk-body carbon composition types (which with overvoltage would rapidly heat, then bubble'n'stink), films just quietly (and invisibly) go "pop".
There very likely isn't any damage to transformers. They're hunks of iron, not whispers of silicon and hair-thin wires. Hunks, I tell you. Hunks.
GoatGuy
Old 18th April 2013, 06:01 AM   #9
tomchr is offline tomchr  Canada
tomchr's Avatar
Yeah... The silicon will die before the iron.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Accident - Shorted Cathode to grid!!Hide this!Advertise here!
Partial feedback (anode grid) with cathode follower swordsman Tubes / Valves 6 9th July 2011 06:29 AM
300B SE cathode feedback to grid? alan_982002 Tubes / Valves 3 29th March 2010 01:04 PM
pentode with grid AND cathode tied to gnd? xdissent Tubes / Valves 5 28th December 2007 01:18 PM
Any common cathode (grounded grid) schematics? leadbelly Tubes / Valves 2 24th February 2006 07:29 AM
Diodes in Grid-Cathode Circuit runeight Tubes / Valves 11 5th April 2004 03:23 PM
