Quad 22 interstage cap?
Old 11th April 2013, 04:18 PM   #1
neskor is offline neskor  Serbia
Default Quad 22 interstage cap?
I'm trying to restore my Quad 22 preamp.
On the internet there are two different schematics.
On first early version there is no input cap, interstage cap is 5000pF and output cap is 0.047uF.
In second (improved) version there is a input cap and interstage cap is now 820pF and output is 0.1uF.
Reason for input cap is known, output is changed probably to improve bass respone, but I don't know why this drastic change from 5000pF to 820pF for interstage cap?
Old 11th April 2013, 04:22 PM   #2
DF96 is offline DF96  England
In the later version has R26 been increased in value, perhaps to 10M so that the triode now uses grid current bias? That would explain a change in coupling cap, to maintain the same 20Hz rolloff.
Old 11th April 2013, 04:29 PM   #3
They didn't change R26 in any revision, it was always 1.5M.
Old 11th April 2013, 06:03 PM   #4
I can't believe that they intended a 120Hz LF cutoff. Is this section within a global feedback loop? That might explain it - the change could then reduce subsonic peaking.
Old 17th December 2016, 10:47 PM   #5
advr is offline advr  Netherlands
What should be the best values for C13&C16? 820p and 0.1 uf for a bass response?
Verstuurd vanaf mijn S7 edge met Tapatalk
Old 18th December 2016, 03:00 PM   #6
This is a non-trivial problem, assuming this is within a feedback loop. Get these wrong and you either lose bass, or get a bass peak due to pushing the loop towards instability.
Quad 22 interstage cap?Hide this!Advertise here!
Quad 22 Wiring tinkerbelt Tubes / Valves 5 10th November 2012 04:31 PM
Quad II/ Quad 22 parts/ parts units WANTED hatrack71 Swap Meet 0 3rd March 2011 02:05 PM
WTB: Any Quad II or Quad 22 units- working or not or parts for them hatrack71 Swap Meet 3 29th August 2010 03:46 PM
Zen Quad 22 johnm Tubes / Valves 0 13th June 2008 04:21 PM
Quad 22 Valve Amps WARREN Tubes / Valves 9 11th September 2004 11:39 AM
