Model 601 Tube amp - diyAudio
Old 10th April 2013, 02:24 AM   #1
Default Model 601 Tube amp
I picked up a vintage tube amp today. I have no idea with any details or how to begin to put it to use. Any help would surely be appreciated. On the front it says Model 601 and has a Microphone input. On the rear it has a couple of strange connectors, on the top there is a green wire that is not terminated. It has what resembles a fuse cup.
It has 2 6V6GT, 2 6SL7GT. It has a 4 pin unit that resembles a tube.
On the back it is marked 202000
Old 10th April 2013, 02:53 AM   #2
The green wire plus "dohickey" is the top cap connection for what is likely a metal envelope 6J7 pentode.
The tube with a curved plate and a rod cathode is a photocell. I'm guessing the amp came out of a movie projector.
What look like 2 contact Jones connector sockets are probably speaker connections.
The rectifier is a 5Z4 metal envelope tube.
The power trafo looks "meaty" enough.
Stereo is out, unless you can find an exact mate. The makings of a guitar amp are certainly there. If you want go down that path, have the moderators move this thread to the Instruments and Amps "board".
Eli D.
Old 10th April 2013, 03:05 AM   #3
What would be the pin configuration of the 4 pin power connector?
Old 11th April 2013, 04:35 AM   #4
This amp is part of the Gaumont 601 16mm film projector. The US equivalent would be the Bell & Howell 179. Good luck!
Bell And Howell Gaumont Model 601 Projector Photos by johnvgriffin | Photobucket
http://www.film-tech.com/warehouse/manuals/BH179OS.pdf
B&K model 747 tube tester for EL34 ivershing Equipment & Tools 13 11th April 2015 09:42 AM
Pine model 203 Tube Amp - hot chassis grounding question Rockenstein Instruments and Amps 2 8th February 2012 04:15 AM
Tube Amp reverb noise, no vibrato intensity, unknown model. Help please tedsorvino Instruments and Amps 0 11th March 2008 11:21 AM
B&W 601 midrange cone upgrade markbaron Multi-Way 0 17th May 2006 07:26 PM
bose 601 kostas Multi-Way 3 28th December 2003 01:37 AM
Copyright 1999-2017 diyAudio
