Preamp and inverter on B7G base tubes circuit.
Old 9th April 2013, 08:15 PM   #1
okifaro is offline okifaro
Default Preamp and inverter on B7G base tubes circuit.
Hi All.
Due to a poor quality of the preamp in my Chinese integrated PP amplifier I would like to modify this stage. I have to admit I'm not a valve expert, just starting with this and I have some issues regarding the circuit I "designedĒ. The original input stage with inverter is based on a differential amplifier (attached pre_old.jpg) and itís using two EF95 pentodes tubes. AFAIK this scheme is burdened with some drawbacks and itís far from a perfect one. Main assumption of my modification leaves the existing B7G heptal base, there are two sockets per channel available.
My new preamp stage is described in two section:
1 Ėas an input was chosen a EC92 triode (exactly half of a ECC81) in a circuit of an anode load without a cathode bypass cap
2 Ėthe Long-Tailed Pair phase splitter, this cathode coupled inverter is based on a ECC91 - twin triode with common cathode
This following stage has a quite high gain, if Iím not mistaken 41 and 13, but I am not sure if it have enough gain to swing a EL34 pentode in the PP output stage, regarding that, I donít know how deep a negative feedback is, I only know NFB resistor value (39k). So what do you think my circuit? Can it improve an overall sound quality of this amp? Maybe some other circuit, other tubes (B7G)? Please let me know your opinion,the original preamp and my circuit schemes attached, my load lines of two triodes also Ė resistors and caps values verification would be greatly appreciated.
Thank you, Rafal.
Old 9th April 2013, 11:30 PM   #2
Eli Duttman is offline Eli Duttman  United States
Why not use "classic" Mullard style circuitry, which DC couples the voltage gain tube to the LTP. Put a 10M45S constant current sink in the tail of the LTP and force symmetry between the 2 sides. The 6GK5, an outstanding combination of high μ, high gm, and low RP gets my nod for the voltage amplifier job. The 6J6/ECC91 was "born" to be used in a LTP.
Eli D.
Preamp and inverter on B7G base tubes circuit.Hide this!Advertise here!
12SX7 coin base tubes? Fake? dgta Tubes / Valves 5 7th February 2012 06:16 PM
Need help on the working of this LED inverter circuit voltwomen Everything Else 1 3rd October 2011 07:17 PM
H-bridge inverter circuit microxy Power Supplies 5 23rd April 2011 01:23 AM
6SN7 coin base tubes Burnedfingers Tubes / Valves 3 18th May 2008 02:00 AM
PCB mounting B7G sockets mike.turner Tubes / Valves 7 10th June 2004 01:41 AM
Copyright ©1999-2017 diyAudio
