RH84 amp. Plate is 300V. What voltage...
Old 8th April 2013, 08:37 PM   #1
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default RH84 amp. Plate is 300V. What voltage...
should the screen be for best sound quality?
I have a VB408 to regulate the screen to a particular voltage.
Any ballpark figures? Or links to literature?
If you can see the speaker cone move...it's not hifi.
Old 8th April 2013, 08:44 PM   #2
Schematic attached. The Regulator will end up before the 2k2 resistor. Think I'll leave in the screen resistor?
Old 8th April 2013, 08:51 PM   #3
In the red light district Sy mentions ballpark 280-290?
Old 8th April 2013, 09:42 PM   #4
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
260 to 300 is fine ... but really the answer is more like "80% of plate 5%" ... which was determined empirically from tubes in service. One of the reasons for the "ultra linear tap" on many an output transformer. Transformer "ultralinear" is also quite reactive - meaning, that the screen voltage jumps about quite a bit in response not just to signal passing through the EL84, but also from reverse-EMF from the speakers stepping up into the autotransformer-connected primary. A nice Zener of about 20 volts is a great solution, though rarely used. Could also use 6 ea blue LEDs in series. About the same voltage, and gives that cool-blue glow.
GoatGuy
Old 8th April 2013, 10:19 PM   #5
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
GoatGuy
Tacky! Use a tap at 43% for the screens or as stated 80% of the HT.
Old 8th April 2013, 10:31 PM   #6
GoatGuy's Avatar
Sigh... ever measured that screen grid? No, not the "magic" ratio of 43%, but the actual voltage, my friend? Try it ... and prepare to be amused. GoatGuy
Old 9th April 2013, 08:13 AM   #7
Thanks.
For EL84 the UL tap is 22-24% at least on many UL transformers. The Dynaco Z565 for example.
Old 9th April 2013, 02:35 PM   #8
Andrewbee is offline Andrewbee  Jamaica
Hi Bas,
I built an RH84 many moons ago and it sounded great to me, the best of any SE EL84 I had built before (and there have been many)
I agree 250V - 300V should be fine. Going from memory, my plate voltage was a little over 300V, but seem to remember using a 10k resistor in place of the 2.2k. I never regulated mine but had all intentions to do so. You could always try a zener to drop the B+ and connect that to the screen as a "regulator", add a cap in there as well to kill noise if you think its necessary. If you used a 51V Zener then you should end up with ~ 250V on the screen or as GoatGuy suggested maybe a 20V Zener. I have found these smaller tubes need the voltage on the screen to be on the higher end to produce any power. Just watch the total dissipation of the EL84.
Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 9th April 2013, 02:43 PM   #9
Yes, for the EL84 from what I read, 24% was empirically determined by Mr Hafler to be the winding percentage for the UL tap.
I am not a fan of the UL connection though, I still think of it as a cheaper way out over regulation (flame suit on).
Old 9th April 2013, 02:45 PM   #10
Thanks Andrew.
I'm going to do just that with my RH KT120! But for this little critter I'll use the VB408's I have in my partsbin. They have been in my partsbin for more than a decade now And I'm sure they felt unappreciated.
RH84 amp. Plate is 300V. What voltage...Hide this!Advertise here!
Tubelab SE checkout shows -300V Bias voltage? dagerman Tubelab 25 26th December 2011 01:10 PM
Safe to use 300v wire for much higher voltage? ThuyTN Parts 3 5th March 2011 02:48 PM
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 08:57 PM
Very high plate voltage EL34 amp Boris_The_Blade Tubes / Valves 3 16th May 2007 05:19 AM
Darling amp plate voltage mylesmf Tubes / Valves 14 12th January 2007 05:14 AM
Copyright ©1999-2017 diyAudio
