Amplificator Class A 2 X EL504
Old 8th April 2013, 07:06 PM   #1
jean michel is offline jean michel  France
Exclamation Amplificator Class A 2 X EL504
hello ,
i me stocked 2 tubes EL 504 for build amplificator 2 ways to EL504 .
i research montage to single ended ( for use 2 ways ) ?
i me research to Google.com , not good research completed to value schématic and spécification
sorry , me english is bad .
http://www.diyaudio.com/forums/attac...1&d=1365447815
me tested basic montage to 1 EL 504 to 34 V - 6.3 V , not possible test , so possible error ?
Old 8th April 2013, 07:31 PM   #2
wfmali is offline wfmali  Europe
This might help to get you started:
EL504 Translation
Marcus
Old 8th April 2013, 07:38 PM   #3
EL504 Translation
Marcus
hello ,
tks for translate info , me looking the montage and looking specifique data .
Old 8th April 2013, 08:09 PM   #4
Ketje is offline Ketje  Belgium
Ketje's Avatar
Why don't you try your luck at the Elektor (french) forum?
They are very activ with tube-amplifiers
Tubes audio - ELEKTOR.fr | Électronique : Analogique Numérique Embarqué Microcontrôleurs Audio Test Mesure
Mona
Old 8th April 2013, 08:44 PM   #5
Mona
hello ,
me looking the forum " Elektor " , no link to amplificator to base EL 504 !
hehehe , me research is slow ...
no problem , so instrutive research to " Google " to Home Made .
thank
Old 9th April 2013, 08:28 AM   #6
Cookj is offline Cookj  Belgium
Try this site
Bienvenu(e) sur AuDIYoFan.org
John
Old 19th April 2013, 05:50 AM   #7
hello ,
me build is up
me joint 2 pictures to 1 for " HT " & 1 for use " EL / PL 504 " .
http://www.diyaudio.com/forums/attac...1&d=1366350441
so good for test no up for very good up power , me problem is charged for good use valve to datasheet !
File Type: jpg Alimentation HT - Chauffage des tubes EL 504 ou PL504.jpg (85.9 KB, 854 views)
Old 22nd April 2013, 05:42 PM   #8
hello ,
me build is stop it
so me transformator is very little for good use power , no probleme , the " solution " , HT to 180 V= is downgrade to good 90 V=
me news build to short listing matérial .
2 PL 504 for connected to left and right to 90 V= , use 24 V~ to filament .
me power to 8 Ohms , is very little , use 0.0.. Watts RMS !!!
so not problem , is not drive installed for test .
me montage to screen .
slow build is good appréciate to search link for build .
me first build , i me newbie , no problem , so looking build for up me good build .
bye all
ps : me test to video ...
2 PL 504 en stéreo - 80 V= - Vidéo Dailymotion
Old 3rd May 2013, 12:16 PM   #9
hello all ,
a stable version with my new transformer, j has to re-modify my assembly(editing) for obtenri moves forward badly because I am not good at arithmetic complex, me the power of mwatts 500, him(it) takes(brings) out in 2 x 8 ohms, have there some more of work has to make put the assembly(editing) is stable and he(it) have there not of 12 AX 7 d to use in l imédiat.
Has bientot
Old 3rd May 2013, 08:00 PM   #10
Ketje's Avatar
Two remarks,
you draw a loadline for triode-config,where your schematic shows a penthode-connection.
You can't use a 230/12V mainstransformer with a SE stage.The bais-current will saturate the core.
Mona
Amplificator Class A 2 X EL504Hide this!Advertise here!
Impedans of trafo for EL504 inSE Ryssen Tubes / Valves 10 17th August 2012 09:39 AM
Help with EL504-based amplifier Socram8888 Tubes / Valves 21 16th August 2012 08:21 PM
EL504/PL504 spice model aparatusonitus Tubes / Valves 7 29th January 2009 09:15 PM
Lots of Watts amplificator Genomerics Class D 0 27th February 2007 02:38 AM
Trade EL504 - ? webercarbmann Swap Meet 0 23rd June 2003 11:07 PM
Copyright ©1999-2017 diyAudio
