5 leads pp output transformer - diyAudio
Old 7th April 2013, 02:07 PM   #1
wf1318 is offline wf1318  Hong Kong
Default 5 leads pp output transformer
Hello everyone!
I am new in tube amp, and I have a question about PP Output Transformer.
Above is a 5 leads 5K PP output transformer picture.
P1 to P2 is 5K, B is CT
So, what is the value for UL1 and UL2? How to determine it?
It's that it is a 2.5K-1.25K-0-1.25K-2.5k structure on the primary winding?
Thanks!
Old 8th April 2013, 12:07 PM   #2
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
UL Taps are for Ultralinear push pull operation , they goes to pentode screen , often they are taped at 43% between center tap and plates...
Only way to determine without a datasheet is to apply an AC voltage to the transformer and measure voltages at UL connections ...
2a3 PP output transformer gmant123 Tubes / Valves 6 20th May 2011 10:38 AM
pp output transformer miniblok2 chopchip Tubes / Valves 4 10th August 2010 02:46 AM
Identifying output transformer leads bereanbill Tubes / Valves 7 24th April 2009 02:27 AM
Unbalacing a PP output transformer? dshortt9 Tubes / Valves 19 22nd August 2007 06:20 PM
EL84 PP output transformer for 6L6 PP class A engels Tubes / Valves 8 30th May 2007 09:45 AM
Copyright 1999-2017 diyAudio
