CCS question mA - diyAudio
Old 1st April 2013, 01:57 PM   #1
merlin el mago's Avatar
Default CCS question mA
I want to adjust my CCS current, right tube draws 2,11mA & left tube draws 2,24mA, Have I to set both tubes to 2mA (I use two separate CCS: one per each tube)?
TIA
Felipe
Old 1st April 2013, 01:59 PM   #2
Rundmaus's Avatar
This is difficult to answer without a little more information.
Schematic? Where is the CCS used? Left/Right concerns two stereo channels?
Rundmaus
Old 1st April 2013, 02:16 PM   #3
Is the ECC81 mu-follower, attached schematic used & DN2540 schematic used without the VR tube see left up corner.
Old 1st April 2013, 02:20 PM   #4
Merlin,
I would take your current "sense" resistor value, multiply it by 2.25. Using that calculated number for resistor value, I would then parallel a fixed resistance and trim pot of same value to allow you to adjust it precisely to the 2,00 mA you desire. I used 2.25 to give some leeway +/- on the adjustment. You can then measure the combined resistor value and replace with a fixed or leave it as it is to allow you to adjust as required.
Living Life Doing the Waltz in 4/4 meter.
Old 1st April 2013, 02:23 PM   #5
I see you schema now. Increase the value of your trimmer.
Old 1st April 2013, 02:30 PM   #6
5K Trimmer & 4k75 resistor?
Old 1st April 2013, 05:05 PM   #7
Whats the present value of your trimmer?
Old 1st April 2013, 05:52 PM   #8
1K trimmer
Old 1st April 2013, 06:04 PM   #9
2k resistor and 5k trimmer would work better.
Did you read the thread regarding the use of a DN2540 for <10mA? There might be some better circuits for such low currents.
Originally Posted by SY View Post
It doesn't matter if it's not constant as long as it's large- see DF96's analysis. Unfortunately, the DN2540's impedance is pretty mediocre at low currents. For the 2mA you're seeking, a bipolar cascode will perform much better.
that is from the CCS fixed bias thread.
4ch. Ma Audio p.s. Subsitution question.... amc32 Car Audio 1 19th December 2011 10:49 PM
For sale: 2 x Fivre 2A3 Single Plate, 60 mA + 44 mA emission on Funke W20 2A3 Maniac Swap Meet 3 1st October 2011 12:18 PM
Crown MA-12000i / MA-5000i / MA-9000i jack2040 Solid State 4 8th March 2011 01:21 PM
CCS question woody Tubes / Valves 16 8th August 2005 07:08 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
Copyright 1999-2017 diyAudio
