Identify record player and valve - diyAudio
Old 1st April 2013, 12:15 AM   #1
Default Identify record player and valve
Hi everyone,
I'm hoping someone may be able to help me identify this record player that was given to me or send me in the right direction. The player is in a bakelite (brown) case with all badges etc. missing. The cartridge is an English BSR, but I'm unsure if it's a BSR table. The 7 pin mini tube is missing with no schematic or id of what a replacement would be. The speaker is labelled manafactured by 'EMI' Sydney, Australia. I have attached pics to help.
Thanks guys,
Shawn
Australia
Old 1st April 2013, 12:56 AM   #2
VaNarn is offline VaNarn  Australia
The most likely valve would be a 6AQ5 and the turntable might be a "Monarch" if not a B.S.R. unit
Old 1st April 2013, 01:28 AM   #3
Beyond question, that unit employs a crystal cartridge whose O/P is several volts. A HIGH tracking force is necessary. I would not play anything on that device, except 78 RPM disks of little or no value.
The stack of fins is a selenium rectifier, which is a ticking, toxic, time bomb. It must be replaced by an appropriate number of modern, silicon, diodes.
All electrolytic capacitors, especially the clamp mounted multi-section part, have literally dried out, with the passage of time. Replacement is essential.
While crystal carts. do produce volts of O/P, I doubt the drive needed for a 6AQ5 is present. IMO, the 50C5 or 1 of its lower heater voltage "equivalents" seems more likely. In any event, all of us are guessing.
Eli D.
Old 1st April 2013, 01:39 AM   #4
Many thanks for the quick reply and info gents.
Shawn
Can anyone identify this valve / tube? Dagwood Tubes / Valves 13 27th March 2013 09:57 PM
Old record player Rucyrius Everything Else 0 24th March 2011 02:35 PM
Pleas help identify this McIntosh valve amplifier Rodeodave Tubes / Valves 35 29th March 2010 08:16 PM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
ELC7? I need help to identify this valve pingfloid Tubes / Valves 6 8th December 2004 05:16 AM
Copyright 1999-2017 diyAudio
