| diyAudio Sponsor | ||
Location: Thursday Island, Torres Strait (still Queensland), Australia
If I am driving a tube amp (wave AV-8's) and want to make my own preamp, should I look at preamps that use OPTs?
I like the look of the ultrapath bp, is the 6gm8 wired in parallel? I was thinking of doing something similar with a 6c45. OR perhaps a 26 triode with transformers? I am not really sure of which transformers to get. Does a transformer just work on a ratio ie is a 6k to 600 ohm the same as a 240 volt to 24 volt transformer?? I am using a 24 volt B+ 6922 SRPP at the moment, I am thinking of doing something a little different, any suggestions ?? Adam Harvey |
#2 |
well.. what is the input impedance you are driving?
if the input impedance is high, and you dont have 5 km of cables, you shouldnt need a low-z output (ie. transformer or CF or etc) |
#3 | ||||||
I like it as a general topology, but not with the 6GM8. I also wouldn't parallel 6C45's. Quote:
Zsecondary = Zprimary x (turns ratio)^2 Zprimary is the output impedance of the tube stage alone. Quote:
Otherwise, I agree with Colt45, except the transformers have the advantage of galvanic isolation between stages. The Wave8 is a good, but not great amp, so building a killer pre for it is a bit of a waste unless you'll update it later. |
#4 |
Brett, Do you have a recommendation for the unmarked resistor and cap?
MG |
#5 | |
The cap should be sized as small as possible to give the -3dB corner you want depending on the input Z of the next stage. Smaller caps usually sound better. C = 1/(6.28 x Zin x f3) in F I usually aim for 1Hz. There should also be a shunt resistor after the output cap of 1M. Not strictly neccessary, but reduces thumps if plugging the output whilst powered up, |
#6 |
I have a pair of Wave 8. I use them with a simple passive preamp.
The input sensitivity is 500mV so a passive pre works fine. |
#7 |
These guys do a nice pre-amp kit with output transformers (I have one)
http://www.worldaudiodesign.co.uk They sell the transformers seperately, and they have a sale on right now. Cheers Max |
#8 |
i couldn't agree more the recommendation for 12b4. i just built this guy and what a wonderful preamp! in my system, it's very revealing and has sparking highs.
i'm using b+ of 260v. plate of 12k, running at about 15ma. biasing at 7+v. i'll try a different operating point later. DonJuan |
#9 | |
diyAudio Senior Member
Frank |
#10 | |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 06:10 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 11:44 AM |
| mosfet output for my tube preamplifier | electrofan | Pass Labs | 5 | 12th May 2008 07:22 AM |
| Strange preamplifier output stage | Groundloops | Solid State | 5 | 21st December 2007 02:54 AM |
| Page generated in 0.13023 seconds (79.05% PHP - 20.95% MySQL) with 11 queries |
