Point to Point SET KT88/6550 Build - diyAudio
Old 31st March 2013, 02:20 PM   #1
cgraf is offline cgraf  Switzerland
cgraf's Avatar
Default Point to Point SET KT88/6550 Build
Hi Guys
As more as I try to inform myself as more I get lost ...
After a few nice builds using pcb boards I would like to build an amp using poing-to-point wiring for my next build.
As I don't need a lot of power I thought to build an amp around KT88 tubes, but single ended. Iron to be defined, thought about Tango or Silk will see.
During my searches I found two designs I like: One is from Doug Tuthill, the other one from Jean Hiraga who uses a pp design on the first stage.
I would appreciate a lot some advises on the two designs, especially about the difference on the sound (the expected one). The music I hear most is Jazz and Jazz voices.
Thanks a lot and best regards from Geneva
Christoph
I will attach both schematics for reference.
File Type: png Jean-Hiraga-12AX7-SE-KT88-Tube-Amp-Schematic.png (38.5 KB, 217 views)
Old 31st March 2013, 04:57 PM   #2
rmyauck is offline rmyauck  Canada
Don't know about those , but this seems to be very popular with UL optional with the schem. in the first post over @ diyaudioprojects.
KT88 SE Abdellah (modified by Alex Gendrano) + AK.. - AudioKarma.org Home Audio Stereo Discussion Forums
Scott17 even went on to build a Kit of it partial or full and everyone really liked the sonics. There is more in diyaudio on it before he came out with the kit.
KT88 SE Basic or Master Kit
Point to Point build tips nightanole Construction Tips 3 26th August 2011 02:08 PM
Op point for 6au6/6gu5 in P-G feedback 6550 vanofmonks Tubes / Valves 9 12th September 2010 08:29 PM
Point to Point build info littlerick Chip Amps 8 6th January 2010 11:14 PM
Point to point, from scatch build of the K-12G jmillerdoc Tubes / Valves 0 25th October 2009 12:40 AM
The best bias point for KT88 rossdt Tubes / Valves 0 27th July 2006 06:24 PM
Copyright 1999-2017 diyAudio
