D3a - MOSFET HYBRID CIRCLOTRON
Old 31st March 2013, 10:16 AM   #1
federico is offline federico  Italy
Default D3a - MOSFET HYBRID CIRCLOTRON
Hi all ...... after several years of just reading, here is my first post. I have recently built Andrea Ciuffoli's D3a-Mosfet circlotron amp. I would love to know if anyone on this forum has tried this design, and if anyone can help me tame its excessively bright highs without using a brutal low pass filter ?
Old 31st March 2013, 11:10 AM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
put load across secondary , to linearize >xformer feeding gates while leaning on bias net < mechanismus
dunno - for start put 100K trimmer across secondary , as variable resistor , and start loading it down
sweep at 1W , from 20-20K , while observing output at scope , will help you see what's happening , and to find proper loading
check that you didn't , accidentally, missed somewhere that proper anti-paralel orientation of resistors
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 31st March 2013, 11:55 AM   #3
mctavish is offline mctavish  Austria
Thats a strange way to connect the supressor grid, can you explain why you have chosen to do it this way?
Old 31st March 2013, 12:01 PM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by federico View Post
..... help me tame its excessively bright highs ....
you mean like in, 'theres is no bass'
wrong phase of Interstage ?
Old 31st March 2013, 01:06 PM   #5
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
You must measure the frequency response to verify whether or not that is the cause of the excessive high frequency tonal balance. As indicated by a previous comment, perhaps, it's the low frequencies being 'rolled off' that is making the highs sound raised.
What method are you using to remove D.C. offset at the outputs? A too short D.C. servo time constant, or too small an output coupling capacitor could possibly be the problem should you find the low frequency response to measure poorly.
If the frequency response measure sufficiently flat and extended, then the perception of elevated or overly aggressive sounding high frequencies could conceivably be caused by excessive distortion, or even oscillatory behavior.
Old 31st March 2013, 02:27 PM   #6
DUG is offline DUG  Canada
Originally Posted by Zen Mod View Post
put load across secondary , to linearize >xformer feeding gates while leaning on bias net < mechanismus...
Yes, I would agree this is what is needed.
Right now the gain is proportional to the inductance of the drive transformer's loading of the drive tube.
There is some loading at higher frequencies due to the FET's input capacitance but not much.
Decide what load line the tube should be operating at and calculate through the transformer what the secondary load should be.
I would also clamp the FET's gates to prevent overvoltage. This is one limitations of FETs that should not be ignored.
Vgs max on data sheet.
Happy listening.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 31st March 2013, 03:23 PM   #7
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Very specific recommendations:
[1] Pentode cathode resistor 68 ohms, change to 220 ohms.
[2] Bypass pentode plate transformer primary with 47K, 1 watt resistor in parallel with primary. Carbon composition is just fine for this purpose.
Theory behind #1: every possibility that transformer is running close to saturation. Drop amperes through it, without substantially changing gain. Should have significant effect if hypothesis is correct.
Theory behind #2: inductive load becomes high enough to emphasize transients. Providing a simple resistive "knee" in the response curve gives pentode a real non-transformative load to chew on. May well, by itself, solve problem. Suggestion above to use a 100K pot is good. Be careful - at lower ohm settings, may burn out due to excessive power dissipation. You can put a 15K resistor in series with it, to prevent, but the 15K needs to be 5 watt.
I have a third and fourth suggestion, but they're less likely, and require more difficult wiring changes on the output MOSFETs. By the way - the output mosfets at 2.1 volts may be significantly over-biased. This can cause HF clipping, as they are not particularly linear MOSFETS.
Good luck.
GoatGuy
Old 1st April 2013, 01:03 AM   #8
Originally Posted by GoatGuy View Post
...By the way - the output mosfets at 2.1 volts may be significantly over-biased. This can cause HF clipping, as they are not particularly linear MOSFETS.
Good luck.
GoatGuy
not understanding here.
MOSFETs are in source follower mode.
Old 1st April 2013, 03:44 AM   #9
I'd like to thank all of you guys for all the advice. This is a truly great forum.
Tinitus : no the bass is phenomenal. I've never heard anything like it from all the tube SETs I've built.
Ken : I will try measuring frequency responce (kind of a newbie) however I cannot see any oscillation at any frequency.
DUG : can you explain how I clamp the gates ?
Goatguy : wow that's quite specific (thanks). I will try your suggestions now. Incidentally, I have tried shunting the secondaries with variable R. All the way down to 600 ohms. Very little audible difference.
Old 1st April 2013, 03:46 AM   #10
yup, its the anti-parallel orientation that's the problem !!!!!!!! :-)
D3a - MOSFET HYBRID CIRCLOTRONHide this!Advertise here!
Hybrid Circlotron Amplifier with only 3 components on the signal path audiodesign Tubes / Valves 204 12th January 2015 10:09 AM
Jeffrey's Super Circlotron (hybrid) hidnplayr Tubes / Valves 4 17th August 2011 10:36 PM
Hybrid OTL Circlotron idea revintage Tubes / Valves 85 3rd September 2008 12:06 AM
Hybrid Circlotron ready to build revintage Solid State 16 1st April 2008 09:51 AM
