Suggestions Please - diyAudio
Old 29th March 2013, 07:25 PM   #1
coolzero's Avatar
Default Suggestions Please
Can our good experts suggest some improvements to this phono/pre schematic? Not just part swapping but something theoretical.
Old 29th March 2013, 07:51 PM   #2
DF96 is offline DF96  England
I think that circuit cropped up in another thread a few weeks ago. It has so many weaknesses I can only assume it was designed by someone who was new to valves.
Old 29th March 2013, 07:59 PM   #3
coolzero's Avatar
This is one of the commercially available product BTW .
Can you explain how to overcome these weaknesses?
Old 29th March 2013, 09:20 PM   #4
Redesign it.
I assume you have permission to reproduce the circuit? Perhaps you could identify it. That might make it easier for you to find other threads.
Old 29th March 2013, 09:36 PM   #5
vinylkid58's Avatar
Yaqin MS-12b?
jeff
Old 29th March 2013, 09:40 PM   #6
Every design has its compromises. The tweaked RCA setup I've uploaded will interact badly with a few carts. and SUTs, due to the high CMiller of the 12AX7 triode. OTOH, the tweaks fix the so/so bass extension and WRETCHED drive capability of RCA's original.
BTW, the fellow who made the original drawing (from a narrative I provided), loves "boutique" parts, but good quality, industrial, stuff is fine. Notice the changes in blue.
Eli D.
Old 29th March 2013, 10:31 PM   #7
For simplicity and a shorter path... Wouldn't it be easier to go with a SS based circuit for a Phono pre-amp?
(just asking...)
Old 30th March 2013, 05:18 AM   #8
coolzero's Avatar
Originally Posted by vinylkid58 View Post
Yaqin MS-12b?
jeff
I checked the threads on this model. But nothing solid. All about just replacing parts.
Two things I noticed so far without doing anything to the internals. When using a SUT, sound changes drastically. Transformation was from OK to really nice. I think this constitutes to the fact that the input of this phono is not properly loaded for MC cartridges. I am using a DL103 so 100 ohms resistor in the input would change the sound I believe.
Replacing 12AU7 to 12XT7 changes the sound positively. Assume it is because of the difference in gain of two tubes.
I am a novice in to tube electronics so can someone guide me where to start? I am reading Morgan Jones these days to find some clues but I am an impatient person when comes to DIY
Old 30th March 2013, 07:34 AM   #9
vinylkid58's Avatar
It won't have enough gain without the SUT using a LOMC like a DL-103, so just leave the loading at 47k.
Replacing 12AU7 to 12AT7 changes the sound positively. Assume it is because of the difference in gain of two tubes.
There are a lot of lousy sounding 12AU7's out there. 12BH7 would be a better tube, but draws double (IIRC) the heater current, which could be an issue for the PS trans.
jeff
Old 30th March 2013, 09:48 AM   #10
coolzero's Avatar
jeff
Thanks Jeff.
HEllo and a few suggestions please jcricket Tubes / Valves 4 30th December 2011 09:45 PM
looking for suggestions for my first one moshik008 Multi-Way 5 5th June 2009 06:09 PM
need suggestions please.. oface Full Range 2 23rd March 2005 05:46 AM
Suggestions please.. satelitis Tubes / Valves 1 25th April 2004 12:59 PM
3-way suggestions seangoesbonk Multi-Way 9 22nd June 2002 01:22 AM
Copyright 1999-2017 diyAudio
