Need a bit more power :) - Page 3 - diyAudio
Old 20th April 2013, 01:04 AM   #21
trobbins's Avatar
Tesla- sounds like you don't know the output transformer type (ie. rated primary impedance). Measuring turns ratio using such a large signal and in circuit may be prone to some error or measurement issue. Much safer to just use a 5-12VAC 50/60Hz level on one of the primary halves.
A schematic, although simple, often helps others to not assume what you may have in place. Eg. bypassed cathode bias resistors, bypassed screen voltage, and preamp situation, and exact PI circuit, and with operating DC voltage levels.
The Philips EL86 datasheet for 250V B+ and 200V screen and 300 separate cathode gives 18W output. So your output level sounds fine given mismatch and different screen powering and possibly unknown OT impedance.
Old 20th April 2013, 03:42 PM   #22
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Yes, a schematic would be nice
Old 21st April 2013, 09:31 AM   #23
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
I know but at the moment schematic is on paper and i don't have a scanner here
I will post as soon i'll go work , anyway thanks for replies.
i'll also measure the OT ratio...if only my bench could be a bit less full of stuff
Denon DCD 1520 20-bit or 18-bit? beauty_divine Digital Source 0 9th September 2007 07:41 AM
Using 20 bit data with a pair of old 16 Bit DAC stefanobilliani Digital Source 15 14th January 2007 01:55 AM
24 bit I2S source to 16 bit DAC? chris719 Digital Source 5 18th June 2005 06:24 PM
a bit of power, space and money mark_titano Multi-Way 0 27th November 2004 02:53 PM
use digital attenuation to improve 16-bit CD playback on 24 bit DAC capslock Digital Source 7 9th April 2002 12:18 AM
Copyright 1999-2017 diyAudio
