Can anyone identify this valve / tube? - diyAudio
Old 26th March 2013, 05:04 PM   #1
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Default Can anyone identify this valve / tube?
Hi all
I have a few of these found at the bottom of a mixed batch of valves and have no idea what they are
Cheers
If you keep digging in the garden of failure you will eventually find success
Old 26th March 2013, 05:10 PM   #2
Cubdriver's Avatar
Possibly a Russian 6C19PI?
-Pat
Old 26th March 2013, 05:22 PM   #3
Tubelab_com's Avatar
The Russian 6C19PI is a triode and usually are seen with sharp pointed pins and a "flying saucer" getter.
My guess is a 6360 dual beam tetrode. You will need to follow a few pins to see if they match up with the data sheet. If I'm right, a single tube is a push pull audio output stage that makes 12 watts.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 26th March 2013, 05:22 PM   #4
Dagwood's Avatar
Maybe, I cant find anything showing the end section with the square cut-outs??
Old 26th March 2013, 05:27 PM   #5
Dagwood's Avatar
Hi Gorge
I think your right, cheers will check the data sheet tonight
Old 26th March 2013, 05:34 PM   #6
I have spent the last 5 years sorting through 41 large boxes that contained a total of about 100,000 loose unboxed tubes. I didn't count them all, just one box. I sorted each box by size, tossing all the broken ones. Then by number of pins, then unique features, and so on until they were mostly all sorted.
I found a few that looked like yours and they were all 6360's. The square cutouts on the beam plates were the unique feature that I sorted by. There could be some other tubes that have this feature, but they weren't in my collection.
Old 26th March 2013, 05:35 PM   #7
6L6 is offline 6L6  United States
6L6's Avatar
You have more? That one is likely dead - the getter flash looks oxidized.
Old 26th March 2013, 06:08 PM   #8
Dagwood's Avatar
Hey Gorge.....that would have taken a few evenings!!
Yeah I think there were 3 more in the box, this one is dead as spotted
Old 26th March 2013, 07:05 PM   #9
DF96 is online now DF96  England
Yes, looks like 6360 (QQV03/10 in UK, QQE03/12 in Europe). There are quick-heat directly heated versions too (used in mobile VHF transceivers). Check the heater.
Does it have an etch code?
Old 26th March 2013, 08:15 PM   #10
Dagwood's Avatar
No etch code on this one, will check the others tonight.
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 04:11 AM
Help me to Identify this Tube keshaandrea Tubes / Valves 27 10th May 2013 06:47 PM
Pleas help identify this McIntosh valve amplifier Rodeodave Tubes / Valves 35 29th March 2010 08:16 PM
can't find valve art tube - and glowey tube pic wicked1 Tubes / Valves 23 10th February 2009 12:54 AM
ELC7? I need help to identify this valve pingfloid Tubes / Valves 6 8th December 2004 05:16 AM
Copyright 1999-2017 diyAudio
