33:1 opt for 5:1 use?
Old 26th March 2013, 08:45 AM   #1
bambadoo is offline bambadoo  Norway
Default 33:1 opt for 5:1 use?
Hi
I have a question
AN Audio note dac2.1 balanced(factory) with 6922 tubes and 5:1 IE core opts.
Is it possible to use 33:1 double c-core OPTs for this? What will the result be?
For me I will say lower output impedance and lower volume output .. But I am not excactly sure.
Will it be ok otherwise and if the system as a whole is extremely sensitive (i.e. on the volume knob) will it even be beneficial?
Best Regards
Old 26th March 2013, 05:41 PM   #2
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
With the ratio off that far, I doubt you will get any output.
If you want to go with a "nicer" C core.....keep looking for a matching ratio.....you quite probably will have to get one custom made.
__________________________________________________ _____Rick........
Old 26th March 2013, 09:37 PM   #3
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi!
Basically this is possible, but you need to verify if the 33:1 transformer is suitable to be driven by the circuit in your DAC. You are right it will provide lower output impedance and a gain lower by factor 6-7 which could be beneficial. if your system has too much gain, which you probably meant by it being too sensitive
But wether it is practical for your case even if the new transformer fits to the circuit is another question. With a 5:1 transformer the output impedance is already very low. Going much lower will not gain much. The only advantage you will have is the reduction of the excessive gain. A better approach would be to eliminate that excessive gain.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 27th March 2013, 01:04 PM   #4
DavesNotHere is offline DavesNotHere  United States
sounds like you got too much gain in the preamp.
if you made this preamp,remove the cathode bypass caps to establish a better gain structure.
33:1 opt for 5:1 use?Hide this!Advertise here!
Quad 33 Please help!!! puska Solid State 16 26th September 2011 03:46 PM
33 1/3 gramophones? AnimusDivinus Analogue Source 9 22nd September 2011 06:56 PM
Quad 33 Please Help me !!! puska Solid State 0 22nd October 2008 07:01 PM
quad 33 puska Solid State 0 22nd October 2008 12:53 AM
33,000u/60V and 33,000u/75V Peter Daniel Swap Meet 2 7th March 2003 01:36 PM
Copyright ©1999-2017 diyAudio
