diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   ECC81 mu-follower problem (http://www.diyaudio.com/forums/tubes-valves/232779-ecc81-mu-follower.html)
merlin el mago 25th March 2013 04:57 PM
1 Attachment(s)
I have noise in both channels, I do the measurements and the voltage between the two tubes in place of 85V I have 175V after this measurment I tested the heater elevataion and voltage is ok 76V, can be the two tubes are damaged?
Rundmaus 25th March 2013 05:01 PM
Your measurement would mean there is a voltage drop of only 8.7V across the 33k resistor, meaning a plate current in the lower triode of approx 0.2mA. Is that the intended operating point?
Rundmaus
kevinkr 25th March 2013 05:10 PM
There has got to be a wiring or component value error.. There should at least 3mA flowing through that resistor.
Rundmaus 25th March 2013 05:12 PM
Please measure the voltage drop across the 470R cathode resistor to confirm the plate current problem in the lower triode.
Does the heater of the lower valve light up?
Rundmaus
merlin el mago 25th March 2013 05:16 PM
Originally Posted by Rundmaus (http://www.diyaudio.com/forums/tubes-valves/232779-ecc81-mu-follower-post3426827.html#post3426827)
Rundmaus
I have a red LED and measures both channels 1,8V
the 4 heaters have light up
merlin el mago 25th March 2013 05:17 PM
Originally Posted by Rundmaus (http://www.diyaudio.com/forums/tubes-valves/232779-ecc81-mu-follower-post3426814.html#post3426814)
Rundmaus
I measures 175V instead of 85V
kevinkr 25th March 2013 05:17 PM
Filaments wired for 12.6 operation with 6.3V applied?
merlin el mago 25th March 2013 05:19 PM
Rundmaus
No, 33K resistor have to drop from 183,7V to 85V not 175V
merlin el mago 25th March 2013 05:20 PM
Originally Posted by kevinkr (http://www.diyaudio.com/forums/tubes-valves/232779-ecc81-mu-follower-post3426840.html#post3426840)
6.3V
merlin el mago 25th March 2013 05:27 PM
1 Attachment(s)
Enclosed circuit used
Resources saved on this page: MySQL 18.75%
