ECC81 mu-follower problem - Page 7 - diyAudio
Old 11th July 2013, 09:25 AM   #61
merlin el mago's Avatar
Thanks for help & explanation Ian, I learned the lesson how to calculate the NFB
470/47 = 10? not 20dBs?
1000/47 = 21.28 not 25dBs?
Old 11th July 2013, 10:17 AM   #62
ruffrecords's Avatar
x10 = 20dB
x21.28 = 26.6dB
Cheers
Ian
Old 11th July 2013, 12:35 PM   #63
TheGimp is offline TheGimp  United States
TheGimp's Avatar
db = 20 X Log Av
Old 11th July 2013, 12:51 PM   #64
Originally Posted by ruffrecords View Post
x10 = 20dB
x21.28 = 26.6dB
Cheers
Ian
Originally Posted by TheGimp View Post
db = 20 X Log Av
Thanks guys to teacher me
Old 11th July 2013, 12:52 PM   #65
How can calculate the new output impedance?
Old 11th July 2013, 04:47 PM   #66
The output impedance is reduce by the amount of NFB. So if you have 6dB of NFB the output impedance will be halved. If you have 20dB of NFB the output impedance will be reduced to one tenth.
The amount of NFB equals open loop gain in dB minus closed loop gain in dB.
Cheers
Ian
Old 11th July 2013, 05:11 PM   #67
Gain without NFB 58.8dBs Output impedance 267 ohms
Gain with NFB 58.8dBs - 32.2dBs (NFB = 26.6dBs? Output impedance 267 ohms : 10 = 26,7 ohms?
Old 11th July 2013, 05:54 PM   #68
Not quite. Gain without feedback = x58.5 = 35.4dB
Cheers
Ian
Old 11th July 2013, 08:42 PM   #69
Cheers
Ian
And I should have added:
Gain with NFB = 1000/47 = x21.3 = 26.6dB
So NFB = 35.4 - 26.6 = 8.8dB = x2.75
If output impedance without NFB = 267 ohms then output impedance with NFB = 267/2.75 = 97.1 ohms.
Cheers
Ian
Old 12th July 2013, 03:39 PM   #70
Thank you Ian
ECC81 MU-Follower consumption merlin el mago Tubes / Valves 3 7th October 2012 09:42 PM
Mu follower MrCurwen Tubes / Valves 3 13th April 2011 11:46 AM
MU follower - distortion Brit01 Tubes / Valves 25 27th August 2010 11:44 PM
Cascoded mu-follower jnb Tubes / Valves 5 9th September 2007 10:28 PM
CCS vs mu-follower. What's the difference? Radames Tubes / Valves 11 22nd June 2005 03:23 PM
Copyright 1999-2017 diyAudio
