ECC81 mu-follower problem - Page 2 - diyAudio
Old 25th March 2013, 05:35 PM   #11
Rundmaus's Avatar
Do the other voltages on the schematic measure as they should? Voltage across the 560R cathode resistor of the upper triode would be interesting.
Does the red LED light up?
Rundmaus
EDIT: Is the red LED a standard type or did you accidentally stumble upon a low-current LED?
Old 25th March 2013, 06:03 PM   #12
merlin el mago's Avatar
Measured resistor and caps and are OK.
Old 25th March 2013, 06:12 PM   #13
Rundmaus's Avatar
If the LED lights up and there are only 8.7V across the 33k resistor, either there is a wiring error or the LED is a low current type.
But if there is no plate current in the lower triode, there shouldn't be plate current in the upper one either - which would show up in the other voltages being wrong.
Please, give a readout of the voltages around the 560R and check if the LED lights up.
Rundmaus
Old 25th March 2013, 06:26 PM   #14
Rundmaus
Voltage across 560R, left channel 0,881V, right channel 0,939V
The LEDs are 20mA, yes both red LEDs are light up.
Old 25th March 2013, 06:39 PM   #15
B+ 280V
upper cathode left 188,8V
upper cathode right 195V
lower plate left 135,8V
lower plate right 138,7V
Old 25th March 2013, 06:44 PM   #16
Red LEDs pic
Old 25th March 2013, 06:52 PM   #17
Your measurement would mean there is a voltage drop of only 8.7V across the 33k resistor, meaning a plate current in the lower triode of approx 0.2mA. Is that the intended operating point?
Rundmaus
Voltage across 33K
Left channel 51,8V
Right channel 55,2V
Old 25th March 2013, 07:26 PM   #18
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by merlin el mago View Post
.... I tested the heater elevataion and voltage is ok 76V, can be the two tubes are damaged?
quote from Valve Wizard
Heater elevation: Because the upper cathode is at a high voltage it is usually necessary to elevate the heater supply to avoid exceeding the maximum rated heater-cathode voltage (Vhk). For the ECC81 this is 90V, so we would need to elevate the heater by at least 100V.
I have no idea what it means, but thats what it says
only found the figures to look different
or are you saying your measured heater-cathode voltage is 76V, and ok being below 90V
Old 25th March 2013, 07:34 PM   #19
Rundmaus's Avatar
Merlin,
the voltage measurements seem inconsistent:
In the first post you measured 175V where there should be 85V (between tubes = plate of lower tube). Then there are only 8.7V across the 33k resistor.
Now you say that the lower plate is at 135V, leaving approx. 50V across the 33k. Thats 1.5mA plate current. Consistent with 0.9V across the 560R resistor, again approx. 1.5mA plate current.
A bit on the low side, but definitely better than the 175V reading before.
What meter (low internal resistance?) are you using?
Rundmaus
Old 25th March 2013, 07:37 PM   #20
Rundmaus's Avatar
Heater-cathode leakage might be a problem, as the circuit significantly exceeds the specified V_hk limit if the heaters are elevated by only 76V. See tinitus' post.
Rundmaus
ECC81 MU-Follower consumption merlin el mago Tubes / Valves 3 7th October 2012 09:42 PM
Mu follower MrCurwen Tubes / Valves 3 13th April 2011 11:46 AM
MU follower - distortion Brit01 Tubes / Valves 25 27th August 2010 11:44 PM
Cascoded mu-follower jnb Tubes / Valves 5 9th September 2007 10:28 PM
CCS vs mu-follower. What's the difference? Radames Tubes / Valves 11 22nd June 2005 03:23 PM
Copyright 1999-2017 diyAudio
