ECC81 mu-follower problem
Old 25th March 2013, 08:09 PM   #21
Ketje is offline Ketje  Belgium
Ketje's Avatar
You can never get the Vfk within the max. 90V specs for the upper and lower triode at the same time.One cathode almost Gnd level and the other near 200V is to much.
Max.distance is 2x90V !
A solution could be separate tubes for up and down with the upper two (other channel) a heatersource of it's own,200V above Gnd.
Or another tube
Mona
Old 25th March 2013, 08:22 PM   #22
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by tinitus View Post
quote from Valve Wizard
Heater elevation: Because the upper cathode is at a high voltage it is usually necessary to elevate the heater supply to avoid exceeding the maximum rated heater-cathode voltage (Vhk). For the ECC81 this is 90V, so we would need to elevate the heater by at least 100V.
I have no idea what it means, but thats what it says
only found the figures to look different
or are you saying your measured heater-cathode voltage is 76V, and ok being below 90V
Using 100V to elevate the heater like the attached schematic, I measure:
Plate lower triode
Right 137,4V
Left 135,5V
Old 25th March 2013, 08:29 PM   #23
Rundmaus is offline Rundmaus  Germany
Rundmaus's Avatar
Replace the red LED by the 470R and 22 in one channel as shown in the first schematic for testing purposes. Check voltages again afterwards.
Rundmaus
EDIT: If everything else seems ok, the LED bias scheme is the only difference to the schematic with its design voltages. Change back the bias scheme to see if the problem occurs from that.
Old 25th March 2013, 08:29 PM   #24
Or another tube
Mona
With other tube the same measurement.
Old 25th March 2013, 08:36 PM   #25
Rundmaus
Lower plate 103.7V
Old 25th March 2013, 08:40 PM   #26
Rundmaus's Avatar
That is significantly closer to the design value than before. Though still different enough to make me wonder why.
You did not comment on the differences in the earlier measurements: Were the 175V a misreading?
Rundmaus
Old 25th March 2013, 08:57 PM   #27
First post 175V was a typo/mistake
Now heaters elevated to 100V, I guess also helps.
So have I to come back to cathode RC in place of LED?
TIA
Felipe
Old 25th March 2013, 09:11 PM   #28
New elevated heaters used schematic
Old 25th March 2013, 09:18 PM   #29
Rundmaus's Avatar
Not sure about that. I'd have to pull my Morgan Jones copy from below a large stack of physics stuff and read up on mu follower design.
Though I am able to do some fault finding by logical and general circuit design and measurement principles, I have no experience in designing mu followers.
Maybe some of the tube forum masters of old can cut in here?
Rundmaus
Old 25th March 2013, 09:24 PM   #30
Lower plate both cathode RC
right channel 103.7V
left channel 102V
Thanks Rundmaus, how could I reduce to 85V?
ECC81 mu-follower problemHide this!Advertise here!
ECC81 MU-Follower consumption merlin el mago Tubes / Valves 3 7th October 2012 09:42 PM
Mu follower MrCurwen Tubes / Valves 3 13th April 2011 11:46 AM
MU follower - distortion Brit01 Tubes / Valves 25 27th August 2010 11:44 PM
Cascoded mu-follower jnb Tubes / Valves 5 9th September 2007 10:28 PM
CCS vs mu-follower. What's the difference? Radames Tubes / Valves 11 22nd June 2005 03:23 PM
Copyright ©1999-2017 diyAudio
