TO-9105-1 Triodeelectronics output transformer - diyAudio
Old 24th March 2013, 02:16 PM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default TO-9105-1 Triodeelectronics output transformer
anyone have a datasheet? Or hookup sheet? I'm wondering which is b+ and which goes to plate.
Old 24th March 2013, 03:40 PM   #2
SY's Avatar
Usually red to B+, blue to plate. I haven't run into an exception yet for US-made iron.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th March 2013, 04:04 PM   #3
Thanks Stuart!
Old 24th March 2013, 04:09 PM   #4
SY's Avatar
If it catches fire and explodes, you know whom to blame.
Old 24th March 2013, 04:20 PM   #5
Yes ofcourse. I'll blame Kyle Broflovski!
TriodeElectronics Mk3 for rank noob? mattmcl Tubes / Valves 11 10th December 2009 02:14 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
Copyright 1999-2017 diyAudio
