What is your comment about akido linestage? - diyAudio
Old 24th March 2013, 12:43 PM   #1
Default What is your comment about akido linestage?
Hi!
My friend is building an Akido linestage, anyone here has one built? Would you please share your experience with us?
Many thanks!
Old 24th March 2013, 01:10 PM   #2
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Simply search the forum and you will find an awful lot of information.
Old 24th March 2013, 02:54 PM   #3
ok! Let me try.
Old 24th March 2013, 05:32 PM   #4
What are the difference between CCDA and Akido?? Thanks!
Old 24th March 2013, 06:20 PM   #5
brianco's Avatar
CCDA: constant-current-draw amplifier
In listening test section, the designer says that it is not an Aikido. He infers that the Aikido is a lot better a preamp. The CCDA's only real advantage is fewer tubes, therefore cheaper to build.
Old 25th March 2013, 07:56 PM   #6
Just finished breadboarding the Aikido CF using only two tubes. I also built the original Aikido awhile ago. They both pretty much sounds the same to me using the same tubes. The only difference is that the original Aikido has some gain to it. I do not need any gain so will go with the CF version for my final pre-amp. I think its an awesome pre-amp. Very clean and its got some grunt going for it...
Old 25th March 2013, 08:06 PM   #7
Do you have both circuit to share? thanks!
Old 25th March 2013, 09:52 PM   #8
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Tubenstein:
I expect that the enthusiasm of a complete stranger won't be of much help to your friend, but I can definitely say that the Aikido I built is a remarkably musical preamp. It disappears faster than the Bottlehead Foreplay and several commercial products that preceded it in my tube system, presents a broad and deep soundstage and is lively without sounding, in any way, artificial. My satisfaction with the Aikido isn't ego-driven (though the photo below does make me proud); it's a reflection of my admiration for John Broskie's circuit and the enormous amount of help Bas Horneman provided.
Highly recommended.
Scott
Good decisions are derived from experience; experience is derived from bad decisions.
Old 25th March 2013, 10:01 PM   #9
As Rockysdad mentioned, the Aikido has 2 different versions of circuit, which one you're building.
Old 25th March 2013, 10:53 PM   #10
I've seen a circuit online, so which version it is. Since it has 4 tubes for stereo, I assume that is the original version you mentioned, right?
Aikido 6SN7 PreAmp
no comment! R-Carpenter Multi-Way 32 17th March 2013 02:52 AM
Akido help pls kendt Tubes / Valves 4 7th February 2013 09:02 PM
Adding Bal output to Akido Zero Cool Tubes / Valves 0 30th May 2011 03:30 PM
AKIDO Line Stage with PEARL CryoValves & Coolers and Stepped Attenuator Mother of PEARL Swap Meet 2 3rd November 2010 06:12 PM
WTB Akido boards. Tony D. Swap Meet 0 6th December 2009 11:32 PM
Copyright 1999-2017 diyAudio
