Improving preamp's bass response. - diyAudio
Old 23rd March 2013, 12:30 PM   #1
Cassiel is offline Cassiel  Libya
Default Improving preamp's bass response.
Hi folks, my preamp does a little bit of magic with the mids (great for Jazz, acoustic music, female singers) but the bass is kinda soft and not punchy. Do you know any tricks to improve bass response? Compared to a Bryston and a Mark Levinson's it lacks a little in that department. Even though it beats both of them in musicality, noise figure and listening fatigue.
Power supply is the standard CRC filter with a tube rectifier (80). I listen to some ambient, electronic music and, even though it sounds great, the bass is obviously softer, the SS preamps have better bass. My plan is to change the topology of one channel to have the other as a comparison point. But maybe I only have to change the value of the output cap......or maybe add a regulated power supply. Just asking for some advice. Is it worth to try another topology or I should focus on the power supply?
Old 23rd March 2013, 12:35 PM   #2
jan.didden's Avatar
Well, the low end is determined by 'Ck' and the output coupling 'Cap' value.
What are those values?
Edit I see: Cap = 2uF: with a 22k Ra: the Fc = 1/(2*pi*22k*2uF) ~ 5Hz.
Rk = 1k which is 22x as low as Rk so for the same 5Hz you'd want Ck to be like 50uF or better 100uF.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 23rd March 2013, 12:39 PM   #3
DF96 is offline DF96  England
The output cap may need to be bigger - depends on the input impedance of the power amp.
Old 23rd March 2013, 12:39 PM   #4
Vinylsavor's Avatar
Hi!
Did you measure the frequency response? Before doing any modifications it would be a good start to first know where the low frequency roll off actually is. Do the measurement with an appropriate load resistor on the output which should be the same as the input resistance of the power amp your are using this with.
If the low freq roll off is too high, start with the cap values as Jan suggested above
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 23rd March 2013, 12:42 PM   #5
JonSnell Electronic's Avatar
Make Ck 220uF 16Volts and connect the feedback to the anode through a separate capacitor, around 2n2 400 Volts, leaving the coupling capacitor at a value of 220nF 400Volts. With R1 loading the output, the bass roll off will be horrible but if fed by a 2n2 cap as described, should improve the low end gain.
Old 23rd March 2013, 12:52 PM   #6
Thanks guys. Rk is 470 uF. One 6SN7 per channel (parallel triodes). I will start with the changes described here - bigger output cap and, also, that cap in the feedback loop and see what happens. I don't have the equipment to measure the frequency response, alas, I'm just a tinkerer - far, far away from being a pro.
Old 23rd March 2013, 12:57 PM   #7
Vinylsavor's Avatar
Hi Cassiel,
no pro equipment needed really. I would highly recommend to get a scope and a signal gen. Used scopes can be found for small money. Signal generators are cheap too. For something like 200-300 Euros you can get both a scope and generator. This will give you a lot of insight and help to understand things.
Best regards
Thomas
Old 23rd March 2013, 01:37 PM   #8
Originally Posted by Vinylsavor View Post
Hi Cassiel,
Thomas
No doubt about that Thomas. I used to rely on my sense of hearing coupled with a balanced intellect but it sometimes plays me tricks and, besides, it's not as good as it was. Still, that electronic bass should sound louder. Don't need a machine to tell me so. Soldering iron is hot now, let's see (hear) where it gets me.
Old 23rd March 2013, 01:44 PM   #9
This is essentially a bass boost tone control, but fixed. In my opinion, swapping components or changing the circuit is not a convenient route to tone control ever since potentiometers were invented.
Old 23rd March 2013, 02:34 PM   #10
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
LOL... I've long been favoring the school of "potentiometers everywhere" ... they're so darn helpful for experimentation!
Seems to me that the ONLY way the original amplifier has a lack of bass response is if the actual load downstream is substantially lower in A/C impedance than the listed 100K. In which case, just a somewhat higher value output cap is required.
Clearly the Ck/Rk combo is right-sized.
GoatGuy
Improving Bass Response On A Popular Hybrid Design supersonik319 Headphone Systems 5 5th February 2013 10:31 AM
Improving stability and transient response? eem2am Power Supplies 26 30th October 2011 12:12 PM
Improving Stereo Imaging & Off-Axis Response Loren42 Multi-Way 20 8th April 2010 12:58 PM
Improving off-axis response of a 15" alexclaber Multi-Way 24 20th July 2009 03:00 PM
improving bass response - yamaha speakers s115ivs sidpro Multi-Way 1 3rd April 2006 07:40 AM
Copyright 1999-2017 diyAudio
