Selecting 5881's question - diyAudio
Old 22nd March 2013, 02:41 PM   #1
Default Selecting 5881's question
Hi everyone-
I am new to tubes.
I have a 1960's vintage Schulmerich audio amp (marked Model 6-190E, evidently used with Carillons) that needs four 5881 output tubes, two for each (independent) channel. I have had no luck finding a schematic, it has not been powered on yet, and I have little knowledge of the actual circuit requirements.
At this point I just would like to attempt to repair it enough to work, then later perhaps improve/tweak. This is a learning project. I have replaced all electrolytic caps and done a few other repairs. I need to buy four 5881's for this. Could you recommend which ones and which supplier?
I have been recommended to Bob Dobush, in Ohio, of findatube.com. He has four used US green print black base Sylvania's for sale for $15 each plus postage. His opinion is that they will sound better than the Sovtek 5881's (through yenaudiostore on eBay for about that same price). He is evidently reputable, and checks his tubes, but I am unfamiliar with what that might actually mean in his case, or what to ask. Maybe you could suggest questions for me to ask him?
I don't want substitutes at this time, i.e. 6L6 variants etc, since the amp is designed for 5881's. And please, if you recommend other suppliers, don't use acronyms- I won't know who you are referring to! $15 is probably as high as I would want to go for these, at this time.
The other tubes are: 6SJ7 and 6SN7. Neither the power supply transformer nor the output transformer are marked with any info. The outputs are 8-pin octal sockets, and I suspect has taps for 70V as well as 16ohm and 6ohm (not sure yet).
Different question, if I may; why would an amp like this require two separate power line inputs, one for each channel?
Keith Ostertag, Harrisburg PA, Crown amps, Dahlquist DQ-18 speakers, custom NHT1259 subwoofers, Marchand XO, DT880 headphones
Old 22nd March 2013, 03:13 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Personally I would use a set of cheap soviet 6P3S-E for my initial testing.
The two power lines are possibly for each channel (easy to verify) or possibly one for the amp and a feed-through for the preamp.
Post some photos of the underside.
Old 22nd March 2013, 03:18 PM   #3
Yes, one power line to each channel. But why would it need that? Photo is before I replaced caps, etc.
Old 22nd March 2013, 03:30 PM   #4
TheGimp's Avatar
Totally conjecture, but I suspect to save power when using one channel as a mono amp.
Old 22nd March 2013, 03:52 PM   #5
If you haven't done so, change out the black capacitors with the red writing on them; especially the ones that connect to pin 5 of the 5881 sockets. They become leaky and are the main culprit for destroying output tubes.
The way the amp is laid out, it looks like a dual mono amp on one chassis. Very neat.
Hope this helps...
Daniel
Old 22nd March 2013, 04:07 PM   #6
Hi Dan- OK. I assume those with the red lettering are mylar, and might not need replacing... but I do expect to check all of them at some point. I certainly didn't know about those particular ones contributing to the demise of the output tubes, so that's a definite. Thanks!
TheGimp- yea, OK, that's possible. With these power amps (to me) it seems silly to quibble over the cost of power, but then again, if these were used for Carillons it may be that one channel was left on 24/7? I just wanted to make sure there wasn't some electrical reason. Since I plan to modify these for home use, I might as well remove that option and use something more convenient and common.
Old 22nd March 2013, 05:00 PM   #7
They are paper caps and usually go bad because of age. As a rule of thumb, they get replaced because more often than not they are leaky.
They orange/yellow ones are probably bad also. Electrolytics...
Old 22nd March 2013, 05:06 PM   #8
JonSnell Electronic's Avatar
A Sovtek 5881 has slightly larger Anode and can dissipate an extra 5Watts as a result. Apart from that they are electrically similar to a 6L6GC.
Old 22nd March 2013, 06:03 PM   #9
TheGimp's Avatar
Looking at the photo of the bottom it looks like the bias voltage is taken to the output sockets (blue wires from output tube sockets connected to the bias pots).
That should make it easy to adjust the bias for whichever tubes you install but it is done per pair, not per individual tube.
If there is enough latitude in the adjustment you may be able to bias it for the lower dissipation 6L6s (23W).
Old 22nd March 2013, 06:33 PM   #10
Tom Bavis's Avatar
My guess is they wanted 100% redundancy - if anything fails, there's another full unit ready to go... the chimes must go on or nobody will know it's lunch time!
selecting a chip Kitax Chip Amps 24 24th September 2012 05:22 PM
question with selecting transformer hc167 Pass Labs 8 14th September 2011 03:57 AM
Help selecting a thermistor Captn Dave Tubes / Valves 0 13th March 2010 02:10 PM
Help with selecting a Potentiometer DeanP Chip Amps 8 11th April 2007 11:04 PM
selecting drivers iceblueorbitz Multi-Way 4 16th June 2006 10:45 AM
Copyright 1999-2017 diyAudio
