The Midlife Crisis - My 833C Amp Build - Page 4 - diyAudio
Old 25th March 2013, 01:51 AM   #31
Tubelab_com's Avatar
Here is an LTSpice simulation.....About 180mA of grid current is required from the driver circuit.
That's probably about right. I measured about 250 mA and I only had 1500 volts of B+ placing my grid just into the positive region at idle.
I have seen a "low buck" 833A amp that used an ordinary low powered tube amp for a driver with the 833A grid connected to the 16 ohm tap on the OPT.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 25th March 2013, 02:30 AM   #32
Magz is offline Magz  United States
Hey, now there's a product idea for someone...an "Amp Booster" module containing the 833 tubes and the power supplies and input and output jacks.
Just add an 8-10W tube amp and enjoy!
Old 25th March 2013, 07:54 PM   #33
The late Hungarian Tungram factory used to produce the equivalent OT400 thorium cathode UHF transmitter tube for cheap... It is a pity GE took over the factory and they abandoned manufacturing vacuum tubes...
Old 25th March 2013, 08:46 PM   #34
Rundmaus's Avatar
Damn,
I wish I had the money and space for such a mid-life crisis!
Rundmaus,
having a mid-life crisis of only EL34-PP dimensions
Old 26th March 2013, 12:02 AM   #35
multi is offline multi  Australia
I have just finished a 150 watt 572b amp; just as crazy as the monster 833c amp; as i have 105db speakers, but amp only uses 650 volts. I can only just manage to lift it; I use a 500kg lifting trolley if possible.
The monster 833c will need a crane!!!
Phil
Old 27th March 2013, 02:20 AM   #36
Received more parts today...most of the power transformers (picture 1), with a Lundahl 1685 13H choke in the picture for comparison.
From left: two Hammond 369KX for the 6E5P/driver circuits, two 18V, 20A Hammond 165V18 for the 833C filaments, and one Hammond 733A for the 833C B+.
The 733A is massive, as befits a 2500V, 345mA (CCS), 50/60Hz trannie. The 2500V lines come out the TOP of the transformer through separate openings, most likely for isolation from the other lines, so it looks like I'll end up laying it on its face with all the wires inside the chassis for safety - the end bells come off very easily (see picture 2), so that should be no problem.
The 369KX is rated at 450V, 300mA. Since all the supplies will be choke input I need to use higher voltage transformers. I chose ones with AT LEAST double the current ratings I need to operate.
Still waiting on the other 733A and two 159ZL chokes for the filament PS.
I also have two little Hammond BD2E transformers coming for the cooling fan PS, if I decide to go that route. My goal is to get all this into an 18"x22" chassis...it will be tight, I think.
Old 27th March 2013, 02:43 AM   #37
That is the way it was done in the "old days." The wires come out of the top of the transformer so they can go straight to the plate caps on the 866A's.
Old 27th March 2013, 02:49 AM   #38
That makes sense. I thought about using Xenon rectifiers but decided that SS would be smaller, lighter, and a lot safer.
Old 27th March 2013, 09:51 AM   #39
CV6045 is offline CV6045  United Kingdom
CV6045's Avatar
Default 833amp
I love the 2.5kv transformer... I did not know you could get End Bells that big. If you dont mind how much did Hammond charge you for it ? I may just order a couple if I return to my own 833 Beast later.
Old 27th March 2013, 01:39 PM   #40
733A Hammond Manufacturing | 733A-ND | DigiKey
mono block amps with 2 x 833C overkill ? even possible to DIY? Thesoundmen Tubes / Valves 25 9th June 2014 03:27 AM
Good Source for Nice Analog Panel Ammeters for 833C Build? Magz Tubes / Valves 12 7th March 2013 08:49 PM
Small and portable headphone amp Crisis firefart_1st Headphone Systems 15 26th May 2010 09:24 PM
Midrange + midlife crisis ronzeman Multi-Way 7 1st September 2008 03:39 PM
No More Sound Crisis john2890 Everything Else 1 23rd December 2005 07:50 AM
Copyright 1999-2017 diyAudio
