The Midlife Crisis - My 833C Amp Build - Page 37 - diyAudio
Old 8th September 2013, 09:28 AM   #361
hpeter is offline hpeter  Slovakia
hpeter's Avatar
Originally Posted by Magz View Post
Speaking of "Monster Amps with Massive Transformers"...
"no replacement for displacement""
but when fuse blows, any glass types become grenades more or less ?
Best what i could find were ceramic fuses 3,35" SIBA 185000
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H1Pi+µfoll > 2A3_SOV/JJ > LL1660 > STAX SR207 STAX SR007 # LL2748 > 394A > LCLC 4H/100µ
Old 13th September 2013, 02:00 PM   #362
Magz is offline Magz  United States
The machining of the chassis is done.
All chassis parts save the faceplates have been sent off to Landfall Systems to be anodized smooth black (non-brushed finish). I had originally intended to have the top plate chromed to match my preamp but in thinking about it there is going to be so much light given off by the 883s that the last thing I need is a big reflector under them, so black they will be. That ought to help with heat dissipation from the top plate, as well.
Once the anodized parts come back, final assembly can begin!
Old 17th September 2013, 06:49 AM   #363
Defiant is offline Defiant  United States
Defiant's Avatar
Once the amp goes into A2, however, the distortion spectrum changes, with much less 2H and more 3H. The second picture is the spectrum at 84W output into 4 ohms. Distortion is now predominantly 3H, with the 3H at .76%. This is what was seen in all analyses I ran with the amp in A2.
A2 distortion and it's spectra are extremely dependant on the driver. The lower it's output impedance the better. Most A2 amps are transformer coupled, but I've had better results using a very high gm cathode follower directly driving the power tube.
Anecdotally, I've read reports that A2 sounds a little edgier and a little brighter than A1, and those FFT results seem to reinforce that. In any case, most listening will be in A1, except for crescendos and perhaps drunken volume cranking...
I've found that my A2 amps almost never actually transition to A2 unless I am playing it ridiculously loud, or into an inefficient speaker.
Note: in order to get consistent, believable results from this LTSpice analysis, I had to disable all compression, force double precision math, and set max timestep to 1uS. Otherwise, there's a lot of hash and false peaks along the baseline.
Where is the force double precision option? I looked and was unable to find it...
Originally Posted by tomchr View Post
Beware that the simulation is only as good as the models. If your tube model accurately models the tube characteristics and grid current in A2 mode, then you probably get good results. Personally, I've never been able to get accurate prediction of the THD of a tube circuit in LTspice. Especially when the circuit behavior near clipping (or A2) is simulated.
For DC and small-signal AC sims, I generally get a very good match between sims and reality.
~Tom
What we need is to get some talented folks together and hack some native, full fledged modelling code into an open source simulator like ngspice. Something like a vacuum tube version of the BSIM or Ebers-Moll models for semiconductors. It would be a daunting undertaking, but the results would be worth it.
Old 17th September 2013, 12:50 PM   #364
Tubelab_com's Avatar
I built an 845SE that makes 40 WPC in A2. It stays in A1 until 25 watts. A2 is only seen on peaks.....the same peaks where the speaker cone is nearing Xmax. You won't hear the amp's distortion, which on my design is still mostly 2H.
LT spice is good, but vacuum tube models where grid current is involved are usually not so accurate.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 17th September 2013, 12:55 PM   #365
.OPTIONS numdgt=7. Any number more than 6 will force LTSPICE to switch to double precision math on dependent variables.
In fact, here's a little webpage I ran across that talks about doing distortion predictions with LTSpice. Some nice little tidbits in there - notice how when he uses the default settings even his pure voltage source looks like crap!
Distortion measurements with LTSPICE | Audio PerfectionAudio Perfection
Old 18th September 2013, 12:15 PM   #366
Defiant's Avatar
The reason I suggested ngspice is that it is open source. Vacuum tube modelling could be coded directly into the simulation engine, which would allow control of parameters that are very difficult to do (accurately) with the current method of modelling.
Cool, thanks for the info!
Old 18th September 2013, 07:43 PM   #367
Hi Magz,
have You seen this one? It's from ESKA Germany
http://www.produktinfo.conrad.com/da..._3KV_500MA.pdf
It is for 3kV an 6kV...I 'm using the 3kV version.
best regards, Matthias
Old 18th September 2013, 08:00 PM   #368
Originally Posted by Mister Ed View Post
Hi Magz,
Looks like another option for HV fuses. Thanks.
Old 20th September 2013, 11:48 AM   #369
Hi Magz,
Hi Matthias,
Nice tip, thank you!
Do you have a source for a suitable fuse holder, how do you handle this?
Best regards
James
Old 21st September 2013, 02:46 PM   #370
Hi James,
Using the clips for 6.3mm (diameter), they fit for 8mm also...
and selfmade holder.
some Pictures
Best regards, Matthias
mono block amps with 2 x 833C overkill ? even possible to DIY? Thesoundmen Tubes / Valves 25 9th June 2014 02:27 AM
Good Source for Nice Analog Panel Ammeters for 833C Build? Magz Tubes / Valves 12 7th March 2013 07:49 PM
Small and portable headphone amp Crisis firefart_1st Headphone Systems 15 26th May 2010 08:24 PM
Midrange + midlife crisis ronzeman Multi-Way 7 1st September 2008 02:39 PM
No More Sound Crisis john2890 Everything Else 1 23rd December 2005 06:50 AM
Copyright ©1999-2017 diyAudio
