The Midlife Crisis - My 833C Amp Build - Page 28 - diyAudio
Old 12th June 2013, 04:52 PM   #271
rdf is offline rdf  Canada
rdf's Avatar
Love the 6E5P but man was it microphonic. The application was a preamp with a step-down output transformer so it might not be an issue in your application.
Ears aren't microphones.
Old 12th June 2013, 06:28 PM   #272
Magz is offline Magz  United States
Originally Posted by hpeter View Post
how much Vp/Vrms this driver gives ? @1V input/max
6E5P mu is about 30, so 1Vp in gives 30Vp out. That's plenty considering the 833C has a mu of 35 itself, it's not hard to drive. For a 2V input, 2*30*35 = 2100V.
Old 12th June 2013, 06:33 PM   #273
I've dealt with the 26 in my preamp, which can be very microphonic. If I run into issues with that I'll look into mounting the tube socket in a vibration-isolating manner, that seemed to work for the 26.
Old 21st June 2013, 03:04 AM   #274
While still waiting on the OPTs, I made up two Vref boards for the driver circuit using the cascaded 10M90S chips feeding a 47K resistor, and upgraded the adjust pot from a Bourns to a Vishay metal foil with a 10ppm/degC tempco. I also put the 2N60 mosfet follower on this board, along with its associated gate stopper and zener protection diodes (picture 1). In this way I can mount the board with the 2N60 using the chassis as a heat sink and save some space while shortening the wiring considerably over the previous version. A small hole in the side of the chassis will allow for adjustment as needed without cracking open the amp. I then tested it in the circuit and all went well; voltage at the 2N60 source (and thus at the 833C grid) rose 2V or so as it warmed up for the first 10 minutes, then became rock solid. Sines and squares look excellent.
So, this simple Vref works much better than the shunt regulator for setting the 2N60 gate voltage, but I still need a stable shunt reg under the 833C...what to do? I contacted Kevin at K&K Audio and after a few emails back and forth he kindly sent me a tiny upgrade board for his shunt regulator that contains a temperature stabilized Vref - I'll be wiring that in and testing it this weekend. Stay tuned.
File Type: jpg 833 Amp Voltage Source - Mosfet Board.jpg (278.9 KB, 1101 views)
File Type: jpg 833 Amp Voltage Source with input board.jpg (333.2 KB, 1083 views)
Old 23rd June 2013, 01:19 AM   #275
The improved, temp compensated Vref from K&K is definitely a better fit for this application when installed in the shunt regulator. After drifting downward steadily (~3V total) during warmup, the voltage was now steady within +/- 0.1V as opposed to fluctuations of up to 1.6V using the non-compensated, simpler stock Vref. Much better for holding the 833C bias steady. Of course the true test will be in the functioning amp itself.
Picture 1 shows the small Vref board installed on the main board, and picture 2 shows the traces I had to cut and the resistor and cap I needed to add in to get the rest of the circuit compatible with the upgrade. I still need to add in a high quality resistor and fine adjustment pot to R9 on the board (on order), for the test I just used an old 1M pot I had to dial in the voltage. The big TO-247 shunt mosfet is mounted off the board so it's not in the picture.
File Type: jpg 833 Amp Underside of shunt reg board.jpg (257.5 KB, 980 views)
Old 23rd June 2013, 05:51 AM   #276
hpeter is offline hpeter  Slovakia
hpeter's Avatar
if you wrapped bread around this toobs, could make a toast
infraheat powa
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H1Pi+µfoll > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LCLC 4H/100µ
Old 25th June 2013, 06:43 PM   #277
Received a snapshot today from Monolith, this time the powder-coated OPT cans. Next they will pot the OPTs in the cans, let them cure for a few days, and ship them to me, along with the first power supply chokes for the 833 B+.
Anticipation...
Old 26th June 2013, 12:56 AM   #278
Anticipation...
Look really small though,
...I meant the tube next to those transformers
Old 26th June 2013, 07:05 PM   #279
hpeter's Avatar
shoeboxes
Old 14th July 2013, 09:40 PM   #280
So I replaced the 1M carbon pot in the modified shunt regulator with a 220k Vishay bulk foil resistor plus a 50k Bourne Cermet pot, since I suspected that the lousy temp coefficient of the carbon was not optimal - wow, was I right! Now the shunt reg stabilizes to the set voltage within 15 seconds, and stays there without moving at all. That problem is solved, now I just need to see how it holds up while sinking the 833C cathode current.
Monolith has informed me that my OPTs and HV PS chokes are ready, but unfortunately I'll be traveling next week so I won't be able to pick them up at the airport until the week after. Then it's time to put this bad boy together!
mono block amps with 2 x 833C overkill ? even possible to DIY? Thesoundmen Tubes / Valves 25 9th June 2014 02:27 AM
Good Source for Nice Analog Panel Ammeters for 833C Build? Magz Tubes / Valves 12 7th March 2013 07:49 PM
Small and portable headphone amp Crisis firefart_1st Headphone Systems 15 26th May 2010 08:24 PM
Midrange + midlife crisis ronzeman Multi-Way 7 1st September 2008 02:39 PM
No More Sound Crisis john2890 Everything Else 1 23rd December 2005 06:50 AM
Copyright ©1999-2017 diyAudio
